ETHAN1 opened this issue on Jul 31, 2000 ยท 5 posts
ETHAN1 posted Mon, 31 July 2000 at 2:28 PM
Is this possible? thank you!
MadRed posted Mon, 31 July 2000 at 2:41 PM
Easy. Ctrl-U (brings up Surface Materials) select GROUND from the drop-down, select LOAD and hunt down your texture.
Mason posted Mon, 31 July 2000 at 6:12 PM
You alos have to turn on the ground first. Hit ctrl-g and a square with the defualt ground will appear. make sure the display ground shadows option is off so its not grey-ed out.
MadRed posted Mon, 31 July 2000 at 7:57 PM
(I sometimes write in 'shorthand.' You should hear me speak...) Yup. Mason's right. BTW, you can't 'tilt' the ground, but you can replace it with a one-sided square (imitation ground?) which can be tilted as needed.
ETHAN1 posted Tue, 01 August 2000 at 1:41 AM
thanks alot!
