Magik1 opened this issue on Oct 07, 2003 ยท 9 posts
Magik1 posted Tue, 07 October 2003 at 8:47 AM
mateo_sancarlos posted Tue, 07 October 2003 at 3:13 PM
Looking at your spline object, I see there are two points on the pipeline occupying the same coordinates. If you make a spline object with no overlapping points, free envelope, it should have a nice cross-section. But when I import a wavefront.obj exported from Poser as vertex object, then try to save the Carrara file with the vertex object, it says "unknown error" and fails to save. Mac OS X.2.6, C2. And the progress bar pops up a few minutes later, saying 90% saved, where it stays indefinitely. Importing a Poser obj as facet meshes is not sufficient for several operations, and it crashes when trying to convert facet meshes to a vertex object.
Magik1 posted Thu, 09 October 2003 at 7:03 AM
Hey Mateo, Thanks for the response. I'll now look into that!
steama posted Thu, 09 October 2003 at 10:15 AM
I tried the above shape and got the same problems/results. I also tried using a free envelope (and all the others), but, that didn't work either. You should not have to use any extrusion envelope at all on this spline object anyway. I think you found a bug. If you find a way to make the shape work properly please share. My bet is that a free extrusion envelope will not work for you either. Good luck in finding the answer. I hope it works for you.
mateo_sancarlos posted Thu, 09 October 2003 at 1:32 PM
Yes, I found that the envelope didn't make any difference when there are two points on the extrusion path occupying the same coordinates. But when all the points are discreet, the pipeline is reasonably unsquashed and the free envelope allows tweaking of the shape to make it even less squashed.
steama posted Thu, 09 October 2003 at 1:37 PM
I found that to be the case also. Though there still is much left to be desired of the outcome. I think the spline modeler should be doing this much better. I for one call it a BUG.
Pinklet posted Thu, 09 October 2003 at 5:21 PM
I found the same problem in C3 and I haven't modeled this kind of object in a while, but it used to work very well in RayDream.
Animoottori posted Fri, 10 October 2003 at 3:38 AM
Magik1 posted Fri, 10 October 2003 at 7:21 AM
Well thank's all you people. It would certainly seem as though it's a BUG. I'm very dissapointed to hear that it affect's version 3 also as I have just ordered this and am at this moment awaiting it's arrival. I can't believe that someone at Eovia hasn't noticed this yet, don't these company's check and work through their manual's before they put them out? What makes this situation even worse is that I'm a 2d artist very new to 3d and this sort of thing just makes a daunting task (ie.learning 3d) even harder than it allready is! Anyway, thank's again for your trouble all of you! Roy Summers UK
