Yamato opened this issue on Oct 07, 2003 ยท 26 posts
Yamato posted Tue, 07 October 2003 at 1:22 PM
shogakusha posted Tue, 07 October 2003 at 2:08 PM
WOW! As always, your work is superb! I think your image shows a side of P5 Judy that only few could acheive. While I have never thought Judy was attractive, the figure in your image is very attractive. Others here will probably have input, but I believe you could use the free utility 'Objaction Mover' to create an encrypted .pcf difference file that would require owning the original P5 Judy mesh to decode. That might get you past any copyright restrictions. Also, that is not the original Judy Texture, what texture are you using? Thanks for all your hard work! Your generosity to the community is boundless.
Dale B posted Tue, 07 October 2003 at 2:23 PM
-That- is Judy? Very nice work, Yamato-san! Like you, I both like and dislike aspects of Judy. She definitely has an 'unfinished' feel about her. As for releasing the new figure, I believe that Maz's ObjAction Mover would do the trick. It encodes the new file into a .pcf file format, which is unuseable in any other program. To decode it, you would need the 'seed' file, in this case the original Judy.obj. This acts like a key in a PGP session; no other .obj would work as the seed. Mover then decodes the file into the new .obj. I would have to check to see how the cr2 modifications could be distributed, but there are ways to do that, as well. And I'm sure someone with a lot more experience at this will be along shortly to tell you. ;)
alamanos posted Tue, 07 October 2003 at 2:42 PM
Great work... looking forward to it... lately i've been playing quite a bit with judy... she's lighter than V3... she renders twice as fast.. (less polygons i guess)... and the face room... is very powerfull... I think she did get aq bum rap... to bad.. with a little work.. she could have been a great charector...
CrystalDragon posted Tue, 07 October 2003 at 2:54 PM
I love it! ^__^ Best bet is ObjAction Mover by Maz, and is found in the free stuff. ~DM
ronstuff posted Tue, 07 October 2003 at 2:59 PM
Wonderful job! I think this is just what Judy needs... a little makeover by a real pro. As far as polygon count goes, if you render Judy in P5 (and because of micro-polygon displacement smoothing) you get rendered results that are on par with a model with over 250,000 polys. I think Judy has a lot of potential and with better JPs and some new morphs she would be great! Thanks Yamato!
jeharsy posted Tue, 07 October 2003 at 3:26 PM
I love the body is grrrrrreat (oops sorrry ;) LOL) i like the work, its so realistic, one of my obessions is to achieve realism in 3d, and with that body im sure i will, maybe you can also add a tutorial how to ad v3 head. Great work, yamamto i have always admired the way you attach ten ten to every model's body. have a nice day
Berserga posted Tue, 07 October 2003 at 3:38 PM
Awesome as usual. I too like Judy's body. It reminds me of the sensually chubby art styles of Toshihiro Hirano and Haruhiko Mikimoto from the 80s. ^^ glad somebody is improving some of the problems with her. Do you think you could allow commercial renders from this redo of judy? Onegai?? ;;
hauksdottir posted Tue, 07 October 2003 at 5:09 PM
Yamato, The women in the Art Nouveau illustrations of Mucha and the early fantasy art of Frazetta were "sensually chubby" (as Berserga so aptly puts it) and more realistic and approachable than the supermodel-with-tiny-head figures that we Poser users commonly deal with. I like Judy's body. Even though at 5'10" my internal ideal is taller than average, I can appeciate the shorter rounder figures. You are doing a wonderful job here! Carolly
stewer posted Tue, 07 October 2003 at 5:56 PM
I'm using only Judy. The standard face looks like an alien, yes, but it's a matter of minutes to change that in the face room. That being done once and saved to the library, I think she looks a lot better than a stock V2, which looks more like showroom dummy to me - too perfect, not real. I don't feel the need to spend money on dozens of V1/V2/V3 characters when I have lots of faces in the face room for free, and I can use V2 textures.
MeInOhio posted Tue, 07 October 2003 at 6:20 PM
I haven't used Judy, but I'm impressed!
stewer posted Tue, 07 October 2003 at 6:34 PM
New Judy body was made of original Judy mesh. Can I distribute it ? If yes, How to ? I want your opinions. I'm afraid you won't be allowed to distribute the obj file as a whole. But, since obj and cr2 files are both plain text files, it should be possible to apply the "diff" tool that will create a file containing the differences between your modified and the original files. The "patch" tool then can apply your changes to someone else's original files. Diff and patch are usually being used amongst programmers to exchange and distribute modifications to some source code, but they work with any plain text file.
Berserga posted Tue, 07 October 2003 at 7:34 PM
Actually even after extensive morphing my Judys at the very least look mannish, (which certainlly works for some characters.) and more often than not just bizarre. While Vicky base is odd looking she is pretty easy to get good results with no matter what kind of character ya wanna make... young, old, fat, slim, Zeta reticulan grey etc... I like Judy, but she isn't the easiest gal to work with. :)
Wombat posted Tue, 07 October 2003 at 7:41 PM
Hope anybody will do such great work with Don too. Thomas
PheonixRising posted Tue, 07 October 2003 at 8:24 PM
Ok that ahd to be the single most shocking make-over in make-over history
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
DaveK posted Tue, 07 October 2003 at 8:25 PM
Great! I like to use Judy. I like all the female models because of the variation in body type. Thank you in advance. DaveK
Lyrra posted Tue, 07 October 2003 at 8:39 PM
Yamato, Use the Objaction mover or RTE Encoder to encrypt the obj. This will make it so that the user must have Judy original obj to uncode the obj. DAZ and Curious Labs both approve these methods for distributing changes. Very very nice work. How much have you changed the polygons? Can we see a wireframe of your version? Lyrra
Zenman53186 posted Tue, 07 October 2003 at 8:41 PM
Very impressive. I've been starting to use Judy more and more once I was able to find a face morph I could live with. I wasn't very successful with the face room. I definitely agree that she could use a few additional polys and perhaps the JCM's that V3 uses so well. I would be very pleased to have access to the work you've done. Thanks very much for your generosity!
Dave-So posted Tue, 07 October 2003 at 8:57 PM
very nice... she needs to be in my runtime :)
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
TrekkieGrrrl posted Wed, 08 October 2003 at 1:18 AM
That is one good looking Judy! Can she still wear Judy's clothes? Or will we have to stick to Dynamic clothing for her?
Momcat posted Wed, 08 October 2003 at 8:07 AM
She is beautiful!! I would have thought she is Tenten >^^< I
never use Judy (for the same reasons you don't like), but I would
use this character. >^^
elgyfu posted Wed, 08 October 2003 at 9:26 AM
Wow, Tenten with curves!! Please, find a way to distribute her coz she really is beautiful and we have all these poor unloved Judies on our hard drives and this is just what they need!!! Hugs, Elgyfu
Berserga posted Wed, 08 October 2003 at 9:44 AM
Yeah the face looks just like Tenten, but the body is definately Judy. :D
Yamato posted Wed, 08 October 2003 at 2:05 PM
Tiny posted Fri, 10 October 2003 at 4:11 PM
"...face looks like an alien, yes, but it's a matter of minutes to change that in the face room..."
Then I must have spent too long time since I only got new aliens as a result... lol
Judy and i do not get along very well.
Yamato: this is increadible work! and I need her in my project as of yesterday! ;o) When is she ready you think?
Lawndart posted Mon, 13 October 2003 at 3:01 PM
Very cool... This is looking nice.
