Forum: Bryce
Subject: How to import a .prj File into Bryce?
ETHAN1 opened this issue on Aug 01, 2000 ยท 8 posts
ETHAN1 posted Tue, 01 August 2000 at 7:57 AM
i found a great scene done with a program using extension .prj but Byrce dont know this fileformat! What can I do? Any convert possibilities???
Spanfarkle posted Tue, 01 August 2000 at 9:30 AM
What is a prj. file? From what app?
ETHAN1 posted Tue, 01 August 2000 at 9:32 AM
Good question! Have a look http://www.3dcafe.com/environ.htm and than view the PCACITY! I need this scence ...
raven posted Tue, 01 August 2000 at 2:27 PM
prj is a project file from 3d studio max. I believe that 3D Explorer has some success at converting prj files to other formats. Hope that helps.
willf posted Wed, 02 August 2000 at 11:33 PM
Bryce 4.0.1 should be able to import prj files (I'm almost positive I've imported some a couple monthes ago). Did you run the updater from 4.0 to 4.0.1?
DbS posted Thu, 03 August 2000 at 2:29 AM
How big is the file? If not humungous, email it to me and I'll convert it to .3ds in Max and wing it on back :) ~Dave
ETHAN1 posted Fri, 04 August 2000 at 1:10 AM
cool thanks! I check the update and in case it doesnt work I send u the file Dave ...
DM1234 posted Sat, 05 August 2000 at 2:22 AM
Actually 4 and 4.01 will both import a prj. The problem is that it comes into Bryce so tiny that at first it'll make you think it didn't work. At least this is the way they've always have imported to Bryce for me. Scale the object or scene big time. Dave
