smalll opened this issue on Oct 08, 2003 ยท 4 posts
smalll posted Wed, 08 October 2003 at 1:17 AM
smalll posted Wed, 08 October 2003 at 2:57 AM
Anthony Appleyard posted Wed, 08 October 2003 at 3:22 AM
If the two parts that meet at an affected joint are P and Q, and P is the normal parent (not IK-parent) of Q, then (at least in Poser 4.0.3):- Select P. Select Poser's menu options Object, Properties. In the resulting dialog box, click the small box "Bend" to make the little X in it disappear. Select Q, and then as for P. Or, if you can trust youself to text edit that model's CR2 file:- - In Q, put a star () at the start of the first title word of any channels named jointX jointx or jointY jointy or jointZ jointz . - In P, put a star () at the start of the title word of any channels named jointX P_jointx or jointY P_jointy or jointZ P_jointz , where P is the name of the part P. - Ditto with channels whose names start "twist". - Similarly with channels whose names start "smoothscale". And remember to save the file in ASCII TEXT mode!
PheonixRising posted Wed, 08 October 2003 at 3:31 AM
you can also double click each bodypart and uncheck "bend"
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
