Subject: Attaching Materials (Textures bitmaps)to Poser figure?
Shaz444 opened this issue on Oct 08, 2003 ยท 1 posts
Shaz444 posted Wed, 08 October 2003 at 5:18 AM
Attached Link: http://www11.brinkster.com/shaaz/ACE/
1. Attaching Materials (Textures bitmaps)to Poser figure? by Shaz444 on 10/6/03 17:24 [Delete] Can anyone guide me to pasting bmp's to a poser figure in POSER 5 materials room? Any help is appreciated. I tried using UVMapper to take the texture map to Adobe Photoshop and paint in OR cut n paste the bmps' parts of images to the texture map, but the UVMapper couldn't give me a proper outline of the figure. So how am I suppose to cut n paste texture maps to a figure? 2. Re: Attaching Materials (Textures bitmaps)to Poser figure? by lynnJonathan on 10/7/03 02:12 Well, I;m not sure about cut and pasteing texture maps. Normally you "load" them (open them) to a material. The Poser 5 manual explains how to go about this. Otherwords you need to save the map from photoshop as a jpeg, or other image file and then load it. This way Poser has a "real" image file to use. At time of rendering it loads this image and renders it however it is mapped to 3D object. It really needs an actual image file. 3. Re: Attaching Materials (Textures bitmaps)to Poser figure? by chriscox on 10/7/03 03:35 Attached Link: http://www.poserpros.com/forums/viewtopic.php?t=6969 Over at Poser Pros (www.poserpros.com) theres a tutorial on applying textures to a figure in Poser 5 (http://www.poserpros.com/forums/viewtopic.php?t=6969) also there is a tutorial on how to make textures for a figure (http://www.poserpros.com/forums/viewtopic.php?t=4030) Chris Cox 4. Re: Attaching Materials (Textures bitmaps)to Poser figure? by Shaz444 on 10/7/03 17:30 [Delete] Author : I have tried out all the above links, but still can't get the result I am looking for. I was thinking of using a bmp image of another model, and utilizing that image areas to cut n paste body parts to Poser 5. For example, image map mapped to a belly button on a poser figure using Nodes in materials room? Any help appreciated?
