Forum: MarketPlace Showcase
Subject: They're here! They're here!
Alleycat169 opened this issue on Oct 09, 2003 ยท 8 posts
Alleycat169 posted Thu, 09 October 2003 at 6:15 PM
Attached Link: Real Emotions for Michael 3
Real Emotions for Michael 3 are finally on sale at daz3d.com! They're more than "expressions", they're "Real Emotions". 50 custom facial expressions, 17 phonemes and 26 eye poses for Michael 3. There's more to making realistic expressions than just spinning dials, or cutting and pasting raised eyebrows and smiles. Real Emotions are carefully created using real human expressions and studies of which facial muscles are effected by different emotions responses. The most complete set of emotions that you'll find anywhere for the best price around. $9.95, but currently on sale for $6.97 for the next two weeks! Don't pay more for smaller expression packs that don't correspond to real emotions. Don't waste time cutting and pasting settings into other applications either. One click does it all with Real Emotions for Michael 3!
sturkwurk posted Fri, 10 October 2003 at 1:57 PM
I bought them immediately Alex... I did have one small problem, the rsr's arent working for my copy of Poser Pro. The V3 emotions rsr's worked fine though, and the poses still work great. I wrote Daz, but havent gotten any response. Doug
I came, I rendered, I'm still broke.
Alleycat169 posted Fri, 10 October 2003 at 2:25 PM
Hmm, that's odd. Sorry you're having problems. Sometimes the fastest way to get tech support from Daz3d is to call their 800 number. If there's a fix needed I'm sure they'll let me know asap. I'm on a Mac so I don't use .rsr's, but I'll write them an email too and maybe that will get things moving faster. Thanks for letting me know.
sturkwurk posted Fri, 10 October 2003 at 3:04 PM
Sure thing, the expressions are outstanding! Doug
sturkwurk posted Fri, 10 October 2003 at 3:11 PM
I just tried to use Poser explorer to convert the rsr's to png format, and I still end up with the shrugging thumbs, even though poser explorer could see the original rsr's just fine. go figure. tempermental program.
guarie posted Fri, 10 October 2003 at 5:34 PM
Is there a " ' " or a " . " in the Folder name? Discovered this by accident that if there is, then no matter what you do, the RSRs will not show up. Remove the offending symbols and viola! Works like a charm. These look good Alex - well done!
sturkwurk posted Fri, 10 October 2003 at 5:46 PM
Thanks Guarie, that wasnt the problem... but it did help point out the problem I think... testing it now... the fc2 poses are called "!AllZero INJ.fc2" while the rsr's are called "!AllZero.rsr" The "INJ" and "REM" are missing from the rsr names! Yep, THAT FIXED IT... you need to add "INJ" and "REM" onto the .rsr names... with a space preceeding it... or just copy the fc2 name over to the rsr without changing the suffix. Again, this is an awesome pack, along with the V3 emotions, it saves a TON OF TIME by not having to load all of the morphs for an expression. Doug
Alleycat169 posted Fri, 10 October 2003 at 9:13 PM
Aha! I knew it had to be something simple like that. I'll relay the message to daz3d tech support and have them fix it. Thanks for taking the time to figure that out, and thanks again for buying my products. I'm glad you like them and that they're saving you lots of time that is better spent elsewhere.
