Subject: Poser4 and 5 on one harddrive?
Tintifax opened this issue on Oct 10, 2003 ยท 3 posts
Tintifax posted Fri, 10 October 2003 at 11:32 AM
Just purchased the Poser5 from Poser4 upgrade. Seems that Poser5 is now stable enough to be used. The question is: How should I install it? Is it possible to install it seperately, so that Poser4 and 5 can run simultaniously or at least independently? What is the best practice and recommendation. Diskspace is not an issue. Thanks - Tintifax
vilters posted Fri, 10 October 2003 at 11:42 AM
I installed P5 next to P4 because of the bad critics. But I 'v never got problems with P5!! So when I find the time I will clean out P4. They worked for about a year now, nicely nekst to eachother on the same drive. Hope this helps, Tony
Tomsde posted Fri, 10 October 2003 at 11:56 AM
You can't have both programs opened at the same time, but you can have them installed to the same folder with no problems. I have P4 w/PP in the same folder and P5 accesses Poser 4's library with no problems.I use Poser 4 a lot yet, but render in Poser 5 with Firefly. I also have python scripts for lighting that will only run in P4 which I don't have the $ to upgrade right now. I have passed a file from one program to another with absolutely no problem. Eventually I will probably uninstall P4 and just retain it's runtime library. I still store all my 3rd party items in P4, because while P5 can access P4's library, P4 can access P5.
