PandaPride opened this issue on Oct 10, 2003 ยท 9 posts
PandaPride posted Fri, 10 October 2003 at 12:52 PM
I have found that when I cancel during Rendering it takes it a very long time to cancel. As of this moment, I had canceling a rendering and it's still sitting there. Does this happen to anyone else? And is there a way to prevent it? --Essie
sandoppe posted Fri, 10 October 2003 at 12:59 PM
Are you using P5? I do and find that canceling when rendering in the same window is not a problem. However, canceling a render in a new window will result in a "hang". I guess the newest update is suppose to help with some of that, but I never installed it as I pretty much know how to maneuver around the few nuances that P5 has since I updated with the 2.1 or 2.2 updates. I don't have the time to learn new nuances right now :)
Treewarden posted Fri, 10 October 2003 at 1:33 PM
No it still hangs. It takes so long to get out sometimes I just won't cancel. I only do it if I know I goofed real bad on settings.
randym77 posted Fri, 10 October 2003 at 1:53 PM
I have that problem frequently. In fact, I usually save my work before I start to render, because it's quicker to kill Poser via Task Manager, then get back in, than to cancel a render.
queri posted Fri, 10 October 2003 at 2:13 PM
Don't cancel during a render-- it might possibly work,once,but its never a sure a thing and as Randy and Caravaggio say, it is shorter to ctrl-alt-delete than agonise through a cancel. Try to remember to always save before a render-- I'm usually anal about it but forgot last night. It froze. Emily
ford3auss posted Fri, 10 October 2003 at 3:26 PM
Yes i have the same problem and does it piss me...
thip posted Fri, 10 October 2003 at 3:46 PM
Pressing the Escape key is usually faster than clicking the Cancel button. Worth a try, at least.
PandaPride posted Fri, 10 October 2003 at 8:03 PM
I have P5 with the service update #3, as far as I know thats the lastes. It lags so much... gets to be a real pain! I wonder if they will ever fix that! thanks for the input all --Essie
bloodsong posted Mon, 13 October 2003 at 3:36 PM
heyas; DONT DO IT! first, it takes just as long to cancel the render as it does to just finish the blasted render ;) now, it used to work, for me, real good when p5 first came out, and it would cancel right away, nice and neat. but not these days. if you start to render and realize you made a boo-boo, just let it finish and then fix it ;)
