Butch opened this issue on Aug 03, 2000 ยท 8 posts
Butch posted Thu, 03 August 2000 at 12:34 PM
Is it possible to add ruffles or lace to clothes or a texture? Working on a couple of new characters and ruffles and lace would help a lot. thanks butch
CharlieBrown posted Thu, 03 August 2000 at 2:03 PM
Kind of, in Poser 4. It's probably easier to do post render, but if you make a careful transparancy map you can do lace. Ruffles would require either a Bump map or combined bump and texture maps, and would probably work best as their own separate mesh.
jje posted Thu, 03 August 2000 at 2:12 PM
I'd have to give ruffles a bit of thought but lace should be easy: 1) create your lace pattern 2) Apply it to your clothing tex in the way that you want. (For the sake of argument here lets say we are using the hem) 3) in P'shop or your favorite gfx application take that texture, invert it and turn it to grayscale. Save that new file as XXX_trans.jpg 4) apply that trans tex to the transparancy channel in Poser and crank the Trans_min and Trans_max sliders to 100% Note: make sure you apply the texture to the entire clothing object and not just part of it. For a different effect, import a 2nd identical clothing object on top of your first (you may have to scale it up the slightest bit) and apply your texture and transmap to it. Giving the effect of a lace covering over fabric.
pam posted Thu, 03 August 2000 at 7:40 PM
I do not know if it will help, but I have an "Elizabethan" lace collar in free stuff, one of those starched lace torture devices Queen Elizabeth wore... pam
Butch posted Thu, 03 August 2000 at 8:13 PM
Pam, I saw the collar and do have it. I haven't thought of that. Give me an idea or two. Thanks butch
Nance posted Fri, 04 August 2000 at 1:08 AM
Was working on a ruffled shirt photo texure & bumpmap for Gabe's Unbuttonable Shirt but never finished the knot at the bottom.
Butch posted Fri, 04 August 2000 at 6:21 AM
Could you send me the ruffle texture? thanks butch
Nance posted Sat, 05 August 2000 at 2:09 AM
Sure Butch, but I'll have to look for it. The maps have a lot of Photoshop work (contrast & sharpening) to the original photo (dl'd from usenet) so I'll send both if I can find them.
