d_authority opened this issue on Oct 21, 2003 ยท 8 posts
d_authority posted Tue, 21 October 2003 at 4:48 AM
usslopez posted Tue, 21 October 2003 at 7:39 AM
I had the same problem but the IPB was not pointing to M3 and I didn't see that for a while. I uninstalled (delete) and reinstalled everything with the updates then it worked correctly.
rbtwhiz posted Tue, 21 October 2003 at 9:44 AM
From what you describe, it sounds as if you are not selecting 'Michael 3' in the 'Figure' dialog (F2) prior to processing the face file. The default option is 'Victoria 3', as such IPB is using an internal dictionary containing file paths that are specific to the selected figure, Victoria 3. The resultant pose is likely injecting delta information as it should, the problem, however, is that it is information specific to Victoria 3. -Rob
Grace37 posted Tue, 21 October 2003 at 9:49 AM
well i had the same problem just re inject the proper morphs and they will take effect
d_authority posted Tue, 21 October 2003 at 12:39 PM
i chose michael 3 in the figure dialog (f2) but it doesnt work.
drdavis79 posted Sun, 21 December 2003 at 11:44 AM
I'm having the EXACT same problem as we speak, did you ever get it figured out??
d_authority posted Sun, 21 December 2003 at 9:11 PM
no. i abandoned the idea.
drdavis79 posted Sun, 21 December 2003 at 9:41 PM
I just got it to work by re-installing IPB and the patch over the old one and it worked just fine. Just make sure that you install the patch IMMEDIATEly after installing the base program. Do it before you open ANY cr2's or anything.
