Subject: need little props to electrostimulate my figure
kyo opened this issue on Oct 22, 2003 ยท 6 posts
kyo posted Wed, 22 October 2003 at 9:20 AM
hi ! talented 3d modellers needed.. as you can see in the pic, i'm looking for a realistic effect to illustrate a medecine book for electrostimulation device : with electrodes applied on skin in differents part of the body... my first try was to paint directly on the texture (pic below) but you can see the stretched effect in the corners of the electrodes square : not good :-) then , i'm asking to me how to realize the more realistic effect, well, props will be the good answer... what i need : a rounded square 5x5 and a rounded rectangle 5x10 with the ability to curve in a horizontal and vertical way, or another solution for a perfect skin-electrode contact curvature if i enable the collision detection.... but i'm definitely not a 3d modeller even for such easy-to-do pieces, if someone could build it for me or give a good tutorial it will be a time saver for me... thanks to anyone and keep up the good work with poser :-))
