Forum: Carrara
Subject: Import Illustrator Paths into Cararra 2?
duality opened this issue on Oct 25, 2003 ยท 5 posts
duality posted Sat, 25 October 2003 at 9:51 PM
I'm just learning Cararra 2 and according to the manual it can import Adobe Illustrator paths. It recognizes the file but when I try it nothing shows up. What am I missing?
chuckerii posted Sat, 25 October 2003 at 10:08 PM
You may have already, but make sure your Illustrator file is saved in version 8.0 or less. Carrara won't read Illustrator files higher than 8.0.
duality posted Sun, 26 October 2003 at 2:55 AM
I tried all versions of illustrator. It recognizes 8 and below and gives me the choice of importing as 3DMF, DXF and wavefront. Of course I'm not sure what options to pick for each choice but each time nothing shows up in the workspace. Hmmmm.
keithw posted Sun, 26 October 2003 at 8:28 AM
It sounds like you are trying to import an AI file into something other than the spline modeler. The spline modeler will allow you to import only ai, ai3 and eps files. Keith
bluetone posted Sun, 26 October 2003 at 6:43 PM
I've done a few logo inports for clients, and the AI importer ONLY works in the spline modeler. If you need to, convert to vertex after importing, for UV mapping, sub-division, etc. I also found that depending on how many points are in the .ai the importer may take awhile to finish creating the model. If they placed 200 ponts on the curves then C has to recognize each, convert it to the points on the cross-section, then extend to the next point on the extrusion line. Good luck!
