Melory opened this issue on Oct 26, 2003 ยท 4 posts
Melory posted Sun, 26 October 2003 at 7:21 PM
ok i took the m3 shorts obj into uvmapper to try to get them to work and this is what i ended up with vertices=6946 textures=7546 normals=0 facets=7043 groups=7 matierals=15 regions=0 I assigned each material to a group rButtock: stripe_rbuttock, pants_rbuttock rThigh: stripe_rthigh, cuff_rthigh, pants_rthigh Hip: stripe_hip, pants_hip Abdomen: stripe_abdomen, pants_abdomen, belt_abdomen lButtock: stripe_lbuttock, pants_lbuttock lThigh: stripe_lthigh, cuff_lthigh, pants_lthigh They still aren't working for me :( Anybody have any suggestions or can tell where I went wrong?
RHaseltine posted Mon, 27 October 2003 at 6:15 AM
Sounds OK, from the original instructions. If you are using Poser 4 on a PC did you delete RSR with the same name as, and in the folder with, the OBJ file? Poser doesn't automatically rebuild that if the OBJ changes. Poser5/ProPack and Mac versions don't use RSR files.
PheonixRising posted Mon, 27 October 2003 at 8:20 AM
well traditionally all body parts are lowercase. If you are using an existing cr2 that is the problem. only with left anf right is the second letter capitalized. abdomen hip lButtock rButtovk lThigh rThigh
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
Melory posted Mon, 27 October 2003 at 9:18 AM
Thanks guys :) having upper case abdomen and hip may be my problem too...i got the shorts to show up...but not those parts :)
