panko opened this issue on Oct 28, 2003 ยท 9 posts
panko posted Tue, 28 October 2003 at 6:07 AM
I have this water polo scene that I made in Poser and I would like to do some postwork painting droplets of water on the players' skins for realism. Any one knows how to go about it, please? Remember I'm going after a close-up "photographic effect" and not a mere simulation. I'm using Photoshop 7.0
"That's another fine mess you got me in to!" -- Oliver Hardy
Hoofdcommissaris posted Tue, 28 October 2003 at 6:57 AM
Attached Link: Good-tutorials: drops
This tutorials look promising... Good luck!panko posted Tue, 28 October 2003 at 9:40 AM
Thanks. You are right... It does look promising.
cryptojoe posted Tue, 28 October 2003 at 8:18 PM
Using no tutorilas, I have discovered a way of making a wet look as well as droplets of fluids:
Find which area's of your picture (ie light colored area's). Using the magic wand, select the high area's, edit > Copy, then open a new document with a transpearent backgound, then paste.
Now, select the highest of these using the magic wand, you may have to use Select > All, then Edit > Copy Edit Paste to get all the highlights individually.
Once you have then use the Filter > Artistic > Plastic Wrap.
You may have to play with the adjustment. You can also adjust selected area's adjusting the bightness, and contrast as well as color balance before and after applying the plastic wrap.
Yank My Doodle, It's a
Dandy!
karosnikov posted Tue, 28 October 2003 at 11:58 PM
urm you can paste this into the same document - it more often than not makes a new layer - or paste into an alpha channel - the filter is applied to the selected layer.. or channel - and can be chosen to have blening options modes if it's a new layer.. etc etc..
dreamer101 posted Wed, 29 October 2003 at 3:58 PM
panko posted Wed, 29 October 2003 at 4:32 PM
retrocity posted Wed, 29 October 2003 at 5:44 PM
weeeeell, if it only cost "two arms" instead of a "leg", you'd be covered ;)
at least according to your pic ;)
retrocity
panko posted Wed, 29 October 2003 at 6:09 PM
Two right arms I believe, retrocity.... LOL
