Gallienus opened this issue on Oct 30, 2003 ยท 7 posts
Gallienus posted Thu, 30 October 2003 at 6:16 PM
Using Poser5 I'm trying to get a piece of clothing to conform to a modified Judy (P5 char.) I have a bikini top which was part of the P4_real_bikini. I brought this in as a prop and divided it into 2 separate props (top & bottom).
I bring it into the cloth room, set up a simulation, reduce the offset distances to a min, select clothify, select the additional collision options, select appropriate body parts to collide against, get a suitable # of dots in my constrained group & hit calculate simulation. But nothing happens. I've tried many permutations of the above but none have worked.
I also have questions about clothing textures & colors but I'll try just one question at a time.
Note: all tutorials on clothing are quite expensive. I can't find any free ones: at least concerning Poser5. If anyone can help I'd very much appreciate it.
PhilC posted Thu, 30 October 2003 at 7:09 PM
Attached Link: http://www.philc.net
Does the bikini fit the figure at the start of the simulation or is any part intersecting the figure. It must fit, not intersect. Can you maybe post a screen shot?I have free Poser 5 cloth room tutorials on my site that you may find helpful.
amberf posted Thu, 30 October 2003 at 7:18 PM
Attached Link: http://www.poserfashion.net/index.htm
Did you try these tutorials?They both have cloth room tutorials. I don't have Poser 5 up right now so I can't quickly check. Do the bikini pieces fit Judy or are you using the cloth room to try to fit it to Judy? Did you want to use it as dynamic cloth or conforming?
...assuming that you're trying to fit the bikini top to Judy and it's too small to fit her...and then you want to make a conformer out of it.
You'll probably have to adjust some of the joint parameters if it doesn't pose well. The 10 frame thing is just me picking a number...I don't think you'd need the default 30 frames...maybe even less than 10 would suffice.
Gallienus posted Thu, 30 October 2003 at 10:26 PM
Hello, Thanks for replying: I'll try these suggestions immediately and let you know what happens. Of course I've heard of the famous PhilC tutorials but when I checked the website I thought they were all for sale @ $32.95 ea. I'll look more carefully.
nerd posted Fri, 31 October 2003 at 12:57 AM Forum Moderator
If that doesn't get you going you can check the tut at Nerd3D as well. The nerd 3D tut is specifically designed to be an introductory tut. Cloth Tut
Gallienus posted Sat, 01 November 2003 at 12:44 PM
HI & thanks for the info. I should mention that I'm really a newbie so I couldn't follow all of your instructions. The parts I had problems with are as follows: 3) When I open up the group tool it defaults to something like "chest". There is also a newgroup & newgroup1 4) Export: export as what a wavefile object *.obj? 5) How do I parent the bikini to Judy? That should be it for now...
nerd posted Sat, 01 November 2003 at 1:11 PM Forum Moderator
Wow, I think we've really confused you. Your half cloth and half conforming and we've made a mess.
OK, conforming and cloth sim are completely different animals and are not related at all.
In a conforming clothing figure your build a model with body parts similar to the ones in the base figure, set up the joint parameters so the clothes bend the same as the target figure... Well this isn't the place for that full tut which is here:
Conforming Clothes
PhilC has an excellent tut on creating conforming figures too.
I think what may be easier, at least at first is to do a Dynamic Cloth. You have already imported the OBJ for the top you are half way there. The cloth sim needs a solid mesh so you don't need to worry about grouping stuff, well not as much any way.
With your bikini model loaded just drag it to position so all the bits that are supposed to be covered are. Now go to the cloth room. From here follow my cloth tut. (It's a click by click tut with lots of pictures :-) )
Cloth Tut Now, there are some issues with using conforming figure models in the cloth room. You may need to use the group tool to select just the polygons that are on the outside of the model and "Spawn" a new prop then use that for your sim. Once again PhilC has doing this covered.
