Subject: BVH motion files help
steveb opened this issue on Oct 31, 2003 ยท 5 posts
steveb posted Fri, 31 October 2003 at 9:21 AM
Hi
I wonder if anyone can help me out with editing BVH motion files.
When loaded into Poser4 they work fine but i want to cut down the length and just use say frame 150 to 250 out of 500 frames.
I have tried editing in poser but it just cuts the key frames and messes up the anim.Went through the manual but there does not seem to be anything mentioned about cutting frames from say 1-149 then say 251-500 so you are left with 100 frames that you want, and be able to save just those
frames.
I had a look in a text editor at a BVH but its does not seem like you can cut out frames as far as i can see.
Have i missed something or maybe it cannot be done, any ideas
would be very helpful.
Thanks
Steveb
geep posted Fri, 31 October 2003 at 10:15 AM
You can do it in Poser. See graphic above. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
iamonk posted Fri, 31 October 2003 at 11:44 AM
Now this is the critter I need help with, all those little boxes scare me.
steveb posted Fri, 31 October 2003 at 2:07 PM
Thanks Dr Geep Thats brilliant i knew some one on this forum would have the info if it was possible. I love the graphic, very easy to see what i have to do. Thanks again Steveb
RealDeal posted Fri, 31 October 2003 at 3:40 PM
Beautiful job.
