mjohn47 opened this issue on Nov 01, 2003 ยท 8 posts
mjohn47 posted Sat, 01 November 2003 at 4:00 PM
In Poser 5, is there a way to lock the height of a camera a fixed distance from the ground? I created a room, and I want to be able to set the camera at eye level (about 6 ft) and lock it at that height but still be able to move it around the room. Also is there a way to figure out distances,in feet,in poser?
geep posted Sat, 01 November 2003 at 7:48 PM
Sure ... first ... Go to [menu]:
"Edit" ---> "General Preferences..." --->"Display Units" to Feet
Then ...
Open the Camera's properties and set yTran to 6.000 (feet).
Double click on the yTran parameter dial to open the Parameter Settings window and set the Min and Max values to 6.000 - then "Use Limits."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sat, 01 November 2003 at 7:56 PM
P.S. You may, also, want to lock the camera's xOrbit to 0 degrees. cheers, dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Little_Dragon posted Sun, 02 November 2003 at 1:15 AM
Never thought about setting limits for the cameras before. Clever.
mjohn47 posted Sun, 02 November 2003 at 1:37 AM
Thanks so much! That works great!
maclean posted Sun, 02 November 2003 at 4:01 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=10139&Form.ShowMessage=1508970
Good tip, geep. It works well. Now..... perhaps you can answer my question in the tech forum. How do I change a camera's center of rotation to get a panoramic swing around a room? macgeep posted Sun, 02 November 2003 at 5:38 PM
Hi Mac, No problem ... watch this forum for a special tut just 4 U. ;=] #44 - "The Room" cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
maclean posted Sun, 02 November 2003 at 5:42 PM
Cool. I can't wait. mac
