Subject: Panther still purple even after update
krbtv opened this issue on Aug 08, 2000 ยท 13 posts
krbtv posted Tue, 08 August 2000 at 7:45 PM
My yellow panther is a little better but still not as gold as the icon. The black panther looks like Barney the purple dinosaur. I ran the update - what has gone wrong?
nitreug posted Tue, 08 August 2000 at 8:15 PM
Mine too.
jval posted Tue, 08 August 2000 at 9:57 PM
Don't know what to say... on my Win machine the updated maps behave as you would expect- nice yellowish Jaguar and a non-purple black panther. Perhaps there is more than 1 update? I'd check with Doug at Zygote. He always gets things fixed up properly though it may take a try or 2.
wyrwulf posted Tue, 08 August 2000 at 10:03 PM
I had the same problem. To fix, I deleted the Panthermap and Panthermap2 from inside Poser, and re-ran the new panthermap EXE The fix installs the new maps, but doesn't overwrite the Cr2 files.
jval posted Tue, 08 August 2000 at 10:08 PM
Ahhh... that explains it, Wyrwulf. Before installing the new maps I renamed and edited the original cr2 files so that I could retain the black & white map and the purple one (in the unlikely event I ever want a "fantastic" panther).
wyrwulf posted Tue, 08 August 2000 at 10:11 PM
Another trick with the Zygote self installers, is to change the path, and install to a folder of your choice. That way, you can look at the setup, make any changes that you want, and then install by copying or moving the folder. I have a shortcut to the top folder "Poser 4" on my desktop, that way I can drag and drop a "Runtime" folder to install.
Daramski posted Tue, 08 August 2000 at 10:30 PM
My panther map, is fine, but listening to you lot talk about this magical panther, makes me want to find out why I havent got that one, LoL Hope you get yours fixed, If doug visits again, maybe a will read the post and let me download it? cheers, Darren
krbtv posted Tue, 08 August 2000 at 10:31 PM
My yellow cat is the same. The Black cat is TOO BLACK. I can hardly see its eyes or teeth. It look like a big black blob.
Kevin posted Wed, 09 August 2000 at 12:01 AM
Try setting the black panther fur material color to near black - try red 30, green 30 and blue 30. The pattern will start showing then. Maybe Zygote uses brighter monitors that most of us?
arcady posted Wed, 09 August 2000 at 10:35 AM
Update? Where's this?
Truth has no value without backing by unfounded belief.
Renderosity Gallery
Kevin posted Wed, 09 August 2000 at 10:41 AM
If you bought it before they fixed it you should get an email from zygote with the details. Otherwise you can write to sales@zygote.com about it and they will tell you.
eallen posted Wed, 09 August 2000 at 12:33 PM
Hello everyone, This is Eric at Zygote. If you have purchased the pantherM and have been set up with a download site you need only redownload from the same site. The update (8-8-00) is available for all who have purchased the pantherM. Please email us with a copy of your receipt at tech@zygote.com . Thanks. Eric Allen Zygote Media Group
Marque posted Wed, 09 August 2000 at 10:36 PM
Anyone care to share the purple texture? I'm off to download the big cat now. =) Marque
