airborne opened this issue on Nov 06, 2003 ยท 3 posts
airborne posted Thu, 06 November 2003 at 9:47 AM
Hi everyone I am a Carrara user and have recently started to use poser 5,SR3. I use the V3 with the bodymorphs, and the morphs from the V3 are transfered to the Cut off jeans (Billy-T). I set the morphs on the V3 and the jeans to have the same value and it looks great. BUT when I conform the jeans to the V3 figure for posing, all the jeansmorphs gets the value=0 , and the jeans does not fit anymore. What am I doing wrong???
steveshanks posted Thu, 06 November 2003 at 1:04 PM
I think you need to add Vicky, add the jeans and conform then do the morphs on Vicky and the jeans will auto morph.....i don't have the jeans but i think that will work..Steve
Little_Dragon posted Fri, 07 November 2003 at 12:45 AM
That trick only works with matching full-body morphs and P4's crosstalk bug. Poser 5 eliminated crosstalk. I think nerd discovered an autoconform workaround for the crosstalk fix, but I haven't read up on it. When you conform an item, all its morphs are set to their default values. The morphs you transferred have a default value of 0, apparently. To change the defaults, first set the clothing figure's morphs, then Edit menu --> Memorize Figure, and resave the item to the Library.
