Forum: MarketPlace Showcase
Subject: New M3 V3 Resource
Ecstasy opened this issue on Nov 14, 2003 ยท 5 posts
Ecstasy posted Fri, 14 November 2003 at 2:17 PM
SoftgoodImage24635a.jpgSoftgoodImage24635b.jpgSoftgoodImage24635c.jpg M3/V3 Resource by Ecstasy -------------------------- Contact Info: Ecstasy-Ecstasy3@ameritech.net -------------------------- Thank you for purchasing the M3/V3 Base for M3/V3 set by Ecstasy. This is a Base character textures set based on Daz's V3 Templates. . 1.The set is for Experinced user of graphic apps and poser. and its intended use is for a quick and easy base to work off of to create your very own M3/V3 texture set to sell or make as a freebie. 2.I encourage you to alter and play with in any paint program of your choice. And anything derived from the sets may be sold or given away as long as they are not in original form and/or to create another base for free or bond. 3.All I ask is that you drop me some credit as the base creator, if not , I wont hunt you down to chop your head off, hey Sh!t happens;-) Its ok. Good luck & enjoy your purchase .Alter the texture set and let me know how much the purchase brings to you. Limmited commercial restrictions apply after purchase. Meaning Line 2. 38 Files. listing in this Zip are as follows: EYEBROW.tif license.txt M3_V3Lips.tif M3_V3eyes.tif M3_V3!Gums.jpg M3_V3HeadBaseEmboss.jpg M3_V3BodyBaseEmboss.jpg M3/V3Body.jpg(Original to the first bases released) M3/V3Head.jpg(Original to the first bases released) M3_V3ABodyBase 01.jpg M3_V3AHeadBase 01 .jpg M3_V3BBodyBase 02.jpg M3_V3BHeadBase 02jpg M3_V3CBodyBase 03.jpg M3_V3CHeadBase 03.jpg M3_V3DBodyBase 04.jpg(Original to the first bases released)updated M3_V3DHeadBase 04.jpg(Original to the first bases released)updated M3_V3EBodyBase 05.jpg M3_V3EHeadBase 05.jpg M3_V3FBodyBase 06.jpg M3_V3FHeadBase 06.jpg M3_V3GBodyBase 07.jpg M3_V3GHeadBase 07.jpg M3_V3HBodyBase 08.jpg M3_V3HHeadBase 08.jpg M3_V3IBodyBase 09.jpg M3_V3IHeadBase 09.jpg M3_V3JBodyBase 010.jpg M3_V3JHeadBase 010.jpg M3_V3KBodyBase 011.jpg M3_V3KHeadBase 011.jpg M3_V3LBodyBase 012.jpg M3_V3LHeadBase 012.jpg M3_V3MBodyBase 013.jpg M3_V3MHeadBase 013.jpg MegaBase readme.txt V3/M3 Head selection.jpg V3/M3BodySelection.jpg There are 3 .tiffs are included that have layers saved to them and a set of templates(no layers) to make marque selections. I use them to help cover seams. Other suggested purchases for use with this set are: "Eowyns" bits and peices, Check herstore for more resource. Fyreworks "treasure chest" there are several to chose from, Please check fyrene's or Gothic angels stores for more resources. Please follow the read me's included with these sets. Rdna has/had photoshop brushes "freebies" by traveler for male body hair . The embossing templates: Embossing is for layering in the choice app of your choice in designing your M3/V3 textures. The body base is 8-bit RGB flat JPEG file, 1875x2500 pixel resolution set at (4.69x6.25 inches) @ 400.00 pixels/inch The Head base is 8-bit RGB flat JPEG file, 3676x2500 pixels (8.17x5.56 inches) @ 450.00 pixels/inchto save on loading time and to save in the detail of the text. I have used this as a transparency layer in photoshop set to Hard light at 32 % I suggest you experiment in your texturing and try it a variants in layering an transparency.
