Subject: Marigold Update
mamba-negra opened this issue on Nov 18, 2003 ยท 6 posts
mamba-negra posted Tue, 18 November 2003 at 7:07 PM
Attached Link: http://www.mambanegra.com/downloads/mgp5-update.zip
Hi Folks, Ronstuff pointed out that my marigold models had some reversed normals, and that P5 was adversly affected when rendering in firefly (I believe it only affected firefly renders...) Well, he was nice enough to offer some corrected geometries up in order to help folks get the most out of P5. If you downloaded the model from Poser Pros (it's been up since a week ago saturday), you should download the attached file. It's only 165K, so it should not take long even on a dial up. Simply extract the files on top of the others (using normal extraction technique...just allow it to replace the old files, though) If you haven't downloaded the model, it will be disappearing in a few days, so you should hurry up if you want it (you should check the readme to see if it has been updated...it will reference Ronstuff as a contributer and have a version of 1.1) This only affects P5 users. For those of us with P4 or PP, the reversed normals have no effect on the final render (from what I can tell) Thanks (and especially...thanks to Ronstuff) Eric
