eelie opened this issue on Nov 20, 2003 ยท 10 posts
eelie posted Thu, 20 November 2003 at 7:00 PM
And I'm getting disgusted too. Ok. I've posted asking for help with the hair and then that "out of memory" error. I finally got the hair. I tried all the suggestions with the error message. Problem is, I'm still getting the error. Arugh! :( I've cut the texture files in half, size-wise. Most were in the 2000x1000 or less range anyway, but I reduced that by half. I also renamed them with shorter file names so I could go in after importing them into Bryce and use the short-name files. They're 8 or 9 characters now. Still, I'm getting the error message. Thinking it might be the hair in general, I saved the one I needed to as an obj by itself, deleted both hair pieces and re-exported just the figures. I figured I'd go back that far and try to add the hair in manually. Now, I can't even get the people to save by themselved! At least I'd gotten that far before all this. I'm confused. Is it possible that the original texture files that Poser is using, even tho I'm overwriting them is still mucking things up? If so, is there a way, without re-doing my modeling, to remove just the textures and export them blank then texture them in Bryce? This is beginning to be almost more trouble that it's worth! :o) Thanks for all the help so far. It's really helped so far. Now if I can just get this last craziness solved, I'll be on my way.
