Djeser opened this issue on Nov 22, 2003 ยท 2 posts
Djeser posted Sat, 22 November 2003 at 1:02 AM
I have the initial build of Vue 4 Pro (since my graphics machine is offline and so I'm unable to update to the newer build). I have been working in the shadow and lighting editor, and haven't been able to get the lighting density to change. It defaults at 100%, but when I change the value to a different number, it doesn't "take" but rather stays at 100%. In regular Vue 4 (4.12), once I change the shadow density for a light, it stays at the value I entered. Is anyone else having this problem? (Vue 4 Pro on W2K, 1G Athlon, 1G DDRAM) I've read through the section in the manual several times (pg 228) and still can't figure out what is going on here. Thanks in advance!
Djeser posted Sat, 22 November 2003 at 3:11 AM
About 20 minutes after I posted the question above, I went to E-on website to check and see if they released any updates for Pro, and lo and behold, the new build was there, and one of the problems fixed in the new build is the shadow density. Downloaded and installed it, and works fine now. In case your computer with Vue 4 Pro isn't online like mine, the update is available at the downloads section. You must have registered to access it.
