Forum: Bryce
Subject: Animation won't load??
wizardangel1 opened this issue on Nov 24, 2003 ยท 4 posts
wizardangel1 posted Mon, 24 November 2003 at 10:36 AM
After repeated tries and rechecking files sizes,pixal heigh showes error. ???? I've check and frames show 300 height. The kb is only 217 ?? It's in jpeg also. Any idea's of what I'm doing wrong? For 3 days I've tried to reload with the same Error coming up. I used a Bryce5 animation clip to start with- then recaptured every 3rd frame as a still to resize and jpeg for reassemble. I used Windows movie maker to reassemble the clip. Thanks for any help you can offer!! Wizardangel1
xceiverx posted Mon, 24 November 2003 at 11:29 AM
Hello Wizard, I think the animation has to be a gif file for it to run the way it should on renderosity. I never had your problem with animation. All mine are gif files. I use Ulead GIF Animator 5 for converting Bryce Animations to gif. Peace
wizardangel1 posted Mon, 24 November 2003 at 11:54 AM
Thanks Xceiverx !! Your works are great and I always check for them -daily!! Yes I've poped in a couple of gif animations myself with no problems. But they started as drawings and photo layer combo's and went gif reasonably clear. Seems the totally Bryce images break-up bad and just don't display clearly--so I was hopeing to bypass gif and use a better image keeping format. Oh well -- guess I'm out of luck . Thanks a ton for your speedy reply --- Wizard
xceiverx posted Mon, 24 November 2003 at 2:27 PM
Your welcome wizard, And thank you :) Hope you work it out would love to see the animations. Peace
