baggettbear opened this issue on Nov 24, 2003 ยท 5 posts
baggettbear posted Mon, 24 November 2003 at 8:55 PM
Mike
sirkrite posted Mon, 24 November 2003 at 9:02 PM
In the material room attach the displacement to the texture and set the displacement value to 0.0025. That should fix it.
baggettbear posted Mon, 24 November 2003 at 9:29 PM
Thanks... I appreciate the quick reply. However, I'm still pretty new at this, and the materials room usually leaves me gasping. Could you be a bit more specific? For the hair prop, there is the usual array of surface values, one of which is "displacement". It does not have a dial, so I assume I would attach a node here, but I'm not sure which one to use. Alternatively, there is also an existing texture file node, but nothing in its options refers to displacement. Mike
Little_Dragon posted Mon, 24 November 2003 at 11:22 PM
After you do so, you can enter a value in the Displacement channel.
Remember to enable displacement in your Render Options, also.
baggettbear posted Mon, 24 November 2003 at 11:32 PM
Great! That worked perfectly. Thanks a bunch. Mike
