miedes opened this issue on Nov 25, 2003 ยท 7 posts
miedes posted Tue, 25 November 2003 at 9:10 AM
How can I conform a dynamic cloth to a figure? Thanks. (Replies in Spanish are best, my english is very poor...)
dialyn posted Tue, 25 November 2003 at 11:31 AM
La ropa dinica no se puede conformar con una figura. Se significa para ser utilizado en el cuarto del pa de Poser 5. Me disculpo por esta traducci pobre... que no hablo espal asque estoy utilizando un traductor. Dynamic clothing cannot be conformed to a figure. It is meant to be used in the cloth room of Poser 5. I apologize for this poor translation...I don't speak Spanish so I am using a translator.
Lawndart posted Tue, 25 November 2003 at 12:10 PM
Attached Link: http://www.3-AXIS.com
You can't conform cloth objects but you can make vertices from the cloth object stick to a body part using the "constrained Group". Example: A Skirt... select the "Edit Constrained Group" button and select the vertices around the top of the skirt in a ring. Now when you do the simulation the "Constrained" vertices will find the closest actor (the hip in this case) and stick to it. Tah Dah... I suggest going to the link (http://market.renderosity.com/softgood.ez?ViewSoftgood=22411) and getting the video from the Renderosity Store. It teaches you ALL about the P5 features including cloth. I do not know Spanish. Can someone translate this for miedes? All the best, Joe www.3-AXIS.comdialyn posted Tue, 25 November 2003 at 12:13 PM
Usted no puede conformarse los objetos del pa sino que usted puede hacer cimas del palillo del objeto del pa a una pieza de cuerpo usando al "grupo obligado". Ejemplo: Una falda... selecciona "corrige el bot a grupo obligado" y selecciona las cimas alrededor de la tapa de la falda en un anillo. Ahora en que usted hace de la simulaci "obligado" las cimas encontrar el agente m cercano (la cadera en este caso) y el palillo a . Tah Dah... Sugiero ir al acoplamiento (http://market.renderosity.com/softgood.ez?ViewSoftgood=22411) y conseguir el veo del almac de Renderosity. Le ense TODO sobre las caracterticas P5 incluyendo el pa. No sespal. Puede alguien traducir esto para los miedes? Todo el la mejor, Joe
dialyn posted Tue, 25 November 2003 at 12:14 PM
I learn something new every day. :)
Lawndart posted Tue, 25 November 2003 at 12:19 PM
dialyn: Glad I could help. Thanks for the translation! Cheers, Joe www.3-AXIS.com
jeharsy posted Tue, 25 November 2003 at 3:14 PM
hehe, tranquilos, yo si hablo espal, mira lo que sucede es que la ropa dinamica esta en "prop" asi que viene siendo como un objeto, lo que tienes que hacer es, en el mismo menu de "conform" abajito dice "parent to" o algo asi, lo que tienes que hacer es `poner, "parent to" al objeto con el"hip" (cintura del personaje) esto se hace seleccionando "hip" en el menu que te sale, y kluego le pones alguna pose al monito, y despues aunque la ropa al principio se vea toda fuera de lugar le pones "dinamics" y solita se va a donde tiene que ir. Por cierto mandame un IM (instant message/mensaje privado) que me encanta conocer gente que hable espal en renderosity. porfis que no se te vaya a olvidar.
