shadowrelm opened this issue on Nov 25, 2003 ยท 7 posts
shadowrelm posted Tue, 25 November 2003 at 12:05 PM
I just baught the pack "just an unbelievable body" and am having a little trouble. I was hopeing some of you that have it can help. There are two kinds of morph dials, adp dials wich there are only a few, and pbm dials of which there are alot. The adp dials can make her breast bigger and the like but the pbm dial seem to have no effect. do I have to buy another add on to make them work or do I have to turn something on? I can't even make her change expression even though there ara dials for that. Can anyone help me to get the most of this seemingly great pack?
Mason posted Tue, 25 November 2003 at 3:14 PM
pbm is sort for poser body morph (probably). Those dials are usually adjusted by the full body Morph in the body dial set. Don't set those for the body parts. Hope that helps.
Charlie_Tuna posted Tue, 25 November 2003 at 3:43 PM
pbm is Partial body morph, a group of morphs that affects more than one part of the figure but not the whole body. :-)
Why shouldn't speech be free? Very little of it is worth anything.
shadowrelm posted Tue, 25 November 2003 at 4:27 PM
Yes but how do you turn them on? when i move the adp dials it effects the body part it coresponds to, but when I move a pbm dial nothing happens. I was wondering how to unlock them so I can manipulate the part of the body that the dial interacts with.
Crescent posted Tue, 25 November 2003 at 5:00 PM
Did you go select the body itself and see if the morphs are there? PBM morphs tend to have their "master morph" located in the body, and work if the body morph is manipulated, not an individual body part morph. Cheers!
-Yggdrasil- posted Tue, 25 November 2003 at 11:55 PM
Also... sometimes PBM morphs are "INJ"ected.
Drew2003 posted Wed, 26 November 2003 at 9:40 AM
The pbm's are "Partial" as in "part of a larger set of inter-related morphs". For instance, if you look in the dials for the figure's chest and see pbmMuscular1, then this is a morph which would be adjusted through use of the Full Body Morph (fbm) called Muscular1. To make it work, what you want to do is look in the "Body" section of the figure, and find fbmMuscular1 (or it may just be called Muscular1) and adjust that dial instead of the pbm dial. For full head morphs, you can also see pbm's in the individual face parts (like the nose or upper lip) while the full morph is in the "head" section. - Drew
