Jim Burton opened this issue on Nov 26, 2003 ยท 15 posts
Jim Burton posted Wed, 26 November 2003 at 7:30 PM
Remember the 3D paint program that came with Metacreations Poser 4? Anybody have any ideas on how to get it to run on Windows 2000? I get a "Not enough memory" message, and I only have 2GB, Shucks! ;-) I get the same message from the old Detailer program, which I also own (which is abandonware, I gather). I can get both of them to run on my old computer in the Win 98 partition, but it would be nice to run it off the new one, as otherwise I gotta do the reconnect the tablet tricks and all that stuff. I just want to correct some simple edges on a texture for Poser, anybody know of a CHEAP 3D program <$100, maybe?
Mattb posted Wed, 26 November 2003 at 8:49 PM
Jim,
Painter 5.5 gave the same error message if the Windows page
file was set over 1023 MB. You may want to see if adjusting this helps.
Matt
EricofSD posted Wed, 26 November 2003 at 9:52 PM
I have dual boot system, win2k and winME. I loaded painter 3d (the full blown app) on ME and then just opened the executable in win2k and it works just fine.
norm1153 posted Thu, 27 November 2003 at 1:10 AM
Boy, that's an argument for a dual OS system! I have only Win2K and WinXP (laptop), but Painter 3D won't run. It has all kinds of problem, beginning with the open file dialog. I also have the full version (only 1 version ever made it to product!). I'm sorry that I can't provide any help. I don't think there is any solution. I'd like to be proven wrong, though. Norm
RHaseltine posted Thu, 27 November 2003 at 5:34 AM
As Mattb says, several of the old Metacreations applications can't count high enough to cope with today's memory spaces - setting a smaller swap file, so that the total of RAM+swap is under 2GB, should fix that problem.
wolf359 posted Thu, 27 November 2003 at 7:20 AM
Why bother !!!! ......seriously Painter 3D is garbage!!!! its one of those moldy peices of unbaked bread that Metacreations (meta who???), tossed over the gate to the unsuspecting faithful o try and bolster their stock value right before fleeing the 3D market for that oh so promising "meta stream" ultimate web tool blah blah blah :-/ there are so many viable solutions for texture painting available today. spare yourself the headache.
iamonk posted Thu, 27 November 2003 at 9:41 AM
Hmmm, I used that a while back. I've always either run 2k or xp, so it is possible. It was slow and sloppy, but worked. Somewhere along the way I even found a fix for the missing import options dialogue. Nowadays I use UVmapperPro with PSP7.
Jim Burton posted Thu, 27 November 2003 at 10:19 AM
wolf359 posted Thu, 27 November 2003 at 11:16 AM
Attached Link: paint shop pro
PSP is $80 if you insist on painting direclty onto 3D object that old Meta C app will suck badly as it has NO open GL or graphic card support so forget about real time previews much like poser itself :-(RHaseltine posted Thu, 27 November 2003 at 12:47 PM
I don't think it's an OS issue - Painter had the same problem, in windows 9x as well as the NT versions. EricofSD is running it in both OSes, so unless there was an installation problem (and it sounds as if Jim Burton has it on his system, just not running) it should be more-or-less XP friendly. It may be MC used a signed integer to report memory availibility - the SimCity 2000 installer told me I had -16MB free on my 32MB machine, and should free more RAM if I wanted it to run (fortunately the game itself was fine).
pakled posted Thu, 27 November 2003 at 12:49 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12353&Form.ShowMessage=1536123
hmm..there's also Project Dogwaffle, which is free..go to the 3d links forum, look for a thread from me, and load it up..there's a section called 'modellers and painters', several packages are there, almost all free (or really cheap). Hang tite..I wish I'd said that.. The Staircase Wit
Khai-J-Bach posted Thu, 27 November 2003 at 3:10 PM
you mean this Project Dogwaffle? - http://market.renderosity.com/softgood.ez?ViewSoftgood=20769 for....$45...........
pakled posted Fri, 28 November 2003 at 9:59 AM
I don't think so..check the links posting above, I downloaded it for free. If that's changed (and doesn't everything), one of these magazines recently had it as a freebie Digit, 3d World, Computer Art..well, I think it did. It used to be free, as recently as August.
Khai-J-Bach posted Fri, 28 November 2003 at 12:08 PM
erm.. yup it's the same program... unless there's 2 of them now.... "Project Dogwaffle version 1.6 Price: $45.00 By Dan_Ritchie [Add Merchant(s) To Favorites] PC Type: PC Only Filesize: 10.45 MB (Too Large?) Uploaded: Jul 2, 2003 ** Coupons cannot be used for purchase Ready to Buy? OR Use Quick Buy if you are ready to checkout after adding this Refund Policies Project Dogwaffle is the Unnatural Paint Program. Not merely an image editor, Project Dogwaffle lets you create original works of art using traditional media tools as well as sophisticated, state of the art paint and animation features. New to version 1.6: Performance o Version 1.6 features a fully overhauled display system for greater speed, quality and flexibility. o Many painting and alpha channel tools have been greatly speed up and improved. Painting tools o New animated brushes let you paint with a sequence of image and are created on the fly as opposed to being a canned effect. They can be scaled, rotated, flipped and keyed, and can make use of brush dynamics just like regular custom brushes. Animation o Onionskin lets you see though your paper like traditional onionskin used in animation studios. Use it with the already powerful painting system to create original cel animations. o You can use animated brushes as an animation tool as well as a painting tool. By holding the Alt key while you paint, you can create remarkable animations as simply as moving the mouse. o Frame sequences can now be loaded and saved in any supported format. o Buffer tools such as flip, invert, grayscale and dynamic range can now be applied to animations. More new features o The new artist guide feature helps you in copying source photographs and artwork. Its one of those tricks artist have been using for ages. o A new shading option in the particle system makes trees and shrubs more realistic. o New SaveAVI and ChangeDPI plugins. Features of Project Dogwaffle: Fast and realistic artist tools, paper, and media styles. Tablet support. Custom and procedural, antialiased brushes and fill types. Over 90 FX filters. Real-time, full screen image processing. Multiple undos. Interactive undo. Automatically recognizes loads of file formats (about 60). Basic layer mixing with buffers. Mix buffers in a variety of ways. Use one buffer to displace, composite, or generally modify another. Bluescreen, greenscreen and color keying. Full alpha channel support. Paint on alpha. Make seamless textures. Animation. Load and save sequences. Union skin for tradional animators. Paint and animate with animated brushes. Stroke player. Paint and animate particles. Paint fractal trees in real-time. Radiant - Advanced lens flares. Fieldpack - Intelligent deinterlace and video retiming. Manage colors with Drag and Drop or create a palette automatically. Modify the interface to suit your preference. Simple, versatile plugin interface. No-pester, non-limited free version. Readme File: Click here to view the readme file for this product."
Jim Burton posted Sat, 29 November 2003 at 5:52 PM
I looked at the Paint Shop Pro page at JSC's (?) site, they don't mention anything at all about painting in 3D, though. I gave up on the Poser version, it gets confused on the OBJ mapping, but I did finally get Detailer working on my Win 98 partition. It actually isn't all that bad! ;-)
