-Yggdrasil- opened this issue on Nov 27, 2003 ยท 13 posts
-Yggdrasil- posted Thu, 27 November 2003 at 6:48 PM
The hair you see on her now is a mixture of Anime Doll Kit hair and Motsura hair, transparency enabled. Firefly rendered, with smooth polygons on and all the other bells and whistles. Took some tips from some rendering suggestions out there. It definitely shows in this portrait. Shame the picture has to be low quality on here (200K ^_^)
Anyways, if anyone knows or has seen hair for her, please let me know! Thanks for your help.
CrystalDragon posted Fri, 28 November 2003 at 1:00 AM
~DM
Caly posted Fri, 28 November 2003 at 12:00 PM
Calypso Dreams... My Art- http://www.calypso-dreams.com
Torulf posted Fri, 28 November 2003 at 2:01 PM
TG
jerr3d posted Fri, 28 November 2003 at 6:30 PM
Nice work Torulf, that really looks like Belldandy!
Torulf posted Fri, 28 November 2003 at 8:16 PM
TG
CrystalDragon posted Sat, 29 November 2003 at 3:24 AM
well, the marks are usually just simple shapes, ever considered a prop? ~DM
Torulf posted Sat, 29 November 2003 at 7:38 AM
Props are not good for the markings on her cheeks. If I change her expressions the prop would not fit. I wont to make animation and its not works with props.
TG
Dale B posted Sat, 29 November 2003 at 2:18 PM
If you are going to do anime animation, the best thing to do for the goddess marks is to copy the face texture you're using under say Bell's name, then add the marks in Photoshop or PSP. You'll probably have to tweak the unshaded color value to get the marking color to look correct in final render, but it would be the easiest way to do it.
CrystalDragon posted Sat, 29 November 2003 at 2:28 PM
It may work, just remeber to check "Inherit bends from parent" when your parenting the prop. Well, then how about using the grouping tool, or an external app to create the marks as new material planes (think that's what they're called). ~DM
-Yggdrasil- posted Sun, 30 November 2003 at 1:16 AM
In mine, I put the markings as textures and fed it through the shader. Works great for renders, but if her markings were to change shape/size like they CAN do, you should use props. I've been looking somewhat into that myself, since Taruru put the blush props into Anime Doll.
-Yggdrasil- posted Sun, 30 November 2003 at 1:19 AM
I'm also looking into putting tatoos and such onto faces, ala .hack or Naruto series. We really need an anime forum. ^_^
Torulf posted Tue, 02 December 2003 at 9:20 PM
TG
