todd71_63116 opened this issue on Nov 28, 2003 ยท 7 posts
todd71_63116 posted Fri, 28 November 2003 at 1:39 PM
i created an arch in illustrator then imported the paths into the spline modeler. i rendered with the hybrid, but the curves arent really smooth theyve got more of a flat line to them. what can i do to make them more rounded?
Kixum posted Fri, 28 November 2003 at 6:44 PM
Can you post an image of what you've got in the spline modeler? You can choose the smooth point tool and pull out a point on a line to smooth it out. -Kix
-Kix
Parkie posted Sat, 29 November 2003 at 1:27 AM
I found that I had to change the Surface Fidelity on the Geometry menu to get smother curves. I use around 200%. this does increase the polygons for the model. Cheers Neil
todd71 posted Sun, 30 November 2003 at 4:26 PM
todd71 posted Sun, 30 November 2003 at 4:28 PM
mateo_sancarlos posted Sun, 30 November 2003 at 10:16 PM
I've noticed Illustrator paths get "unsmoothed" on import; the same path created with beziers in Carrara is smooth (pipeline, centered), but the Illustrator path needs to be redone to smooth it. Otherwise I suppose you could convert to vertex object and use subdivision smoothing level 2 if you want to keep the polygon count low.
todd71 posted Sun, 30 November 2003 at 10:21 PM
hmmm..ok..thanks for the advice...maybe we need a plug in that will import illustrator curves smoothly....=)..lol
