Subject: ummm help with the material room?
SpiceBunny opened this issue on Nov 29, 2003 ยท 7 posts
SpiceBunny posted Sat, 29 November 2003 at 11:29 AM
hi.
i am somewhat lost ... i remembered doing it - making a reflection on a prop - like a square box - using the material room in poser 5. probably was a quirk...
anyway - could someone help me with it? i have been trying to figure how to set the prop to be a mirror with nice lil reflections and all. i tried several tutorials but nothing is working right...
um. .. thanks for reading :) and reply (if applicable)
crocodilian posted Sat, 29 November 2003 at 12:30 PM
Attached Link: http://www.keindesign.de/stefan/poser/firefaq.html#5
are you setting up a reflection node? Stefan Klein has produced a very good FAQ on the Tempest renderer (what Poser calls "Firefly") and addresses your question.
SpiceBunny posted Sat, 29 November 2003 at 9:24 PM
i tried that. ended with patches of dull lines and patches of mirror lines.... very interesting but i never own a mirror like that so that patches are kinda moot.
crocodilian posted Sat, 29 November 2003 at 10:11 PM
" i tried that. ended with patches of dull lines and patches of mirror lines.... very interesting but i never own a mirror like that so that patches are kinda moot." This sounds like the raytracer isn't getting enough samples. Try: --Increasing the bucket size --increasing the pixel samples --decrease the shading rate post an example of what you're getting, along with the parameters you're using. Raytrace reflection is, as you know, a very compute expensive proposition. A cheap "fake", when you don't need to simulate reality perfectly is to do a panoramic render of the room, without raytracing on. Then take that image and fisheye distort it in Photoshop (or whatever). . . Now use this distorted image as the environment map for your reflective surface. This will always need a little tweeking, but works well for un-demanding scenarios (if your character is going to reach out and touch the mirror in an animation, obviously this approach won't do. . .but for a still life its fine)
SpiceBunny posted Sun, 30 November 2003 at 10:48 AM
ok ... got a sample to post... without those :
why i didnt do that? well .. i was hoping i dont have to, ya see. i dont recall doing any changes on them when i did a good mirror image last time (this time i have to keep a note what i do or i ended up asking the same stuff again)
it's a still life image since i dont think i wanna waste doing animation using poser :)
and yes - there's a glossy thingo there ... i was following another tut somewhere... O_o
stewer posted Mon, 01 December 2003 at 6:45 AM
Attached Link: http://www.keindesign.de/stefan/poser/firefaq.html#2
Use the single sided square prop as mirror, the double-sided one causes these artifacts. Or you apply a slight displacement to the square, see the link. It should render fine then.
SpiceBunny posted Mon, 01 December 2003 at 7:19 PM
okie dokie.. will do. will post how it looks like later (at work and well my collegues raise eyebrows when there's even a hint of nudies! plus i dont have poser on this work puter)
