Forum: Carrara
Subject: How do you get this right?
Animoottori opened this issue on Dec 04, 2003 ยท 3 posts
Animoottori posted Thu, 04 December 2003 at 5:29 AM
Hello again! How can I shift the lumberyard shader so that it matches the cuts in my logwall? I tried to change the translation values in the parametric mapping -component of the shader but it is useless. It seems Shader ops could do the trick but I'm not in a position to decide wether to buy it or not. So is there any other way?
pem posted Sun, 14 December 2003 at 10:42 PM
Did you ask the fellow behind what used to be Lost Horzion Software but is now ZMorphics for help? Lumberyard started out as a LHS plugin. Contact support@zmorphics.com
Animoottori posted Mon, 15 December 2003 at 1:51 AM
I'll try that out. Thanks. HK
