isaacnewton opened this issue on Aug 19, 2000 ยท 2 posts
isaacnewton posted Sat, 19 August 2000 at 9:38 AM
I think Carrara has made another whoopsee. This time it has exported an object where only the back facets are visible, from which ever direction I view it, the "front" is invisible, I see straight through it to the "back". Is there a simple way of correcting this error? I have tried reimporting the object with mesh option, not the facet, then exporting again, but that doesn't work. Is this a regular occurence and hence a FAQ? Is there a FAQ list somewhere for Carrara problems? IsaacNewton
ClintH posted Sat, 19 August 2000 at 10:47 AM
Try the Reverse polymesh normals option in the modeler. Select the polymesh that is reversed, give the command to reverse them then re-export. See if that helps. Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
