DrOsborn opened this issue on Dec 07, 2003 ยท 7 posts
DrOsborn posted Sun, 07 December 2003 at 9:30 PM
Hi All.
I am starting of from the beginning. Poser 4, Mike 2, and Mike 2 medium resolution texture from Daz. Can someone point me to a tutorial on how to do eyelashes?
I started out by setting all the body parts in the Material box to white and applied the textures. Now I am down to the white eyelashes. How do I apply them?
Also, in the Materials box the first option is Preview. What is that?
Thanks for the help, DrOsborn
mateo_sancarlos posted Sun, 07 December 2003 at 9:51 PM
Preview is the box color when you move stuff in the document window. Color the lashes black and see if you have a Mike2 head texture called eyelashtrans.jpg or similar, which you apply as the transparency map.
xantor posted Mon, 08 December 2003 at 12:29 AM
when you apply the transparency map change transparency max to 100 and change transparency falloff to 0 (zero) You don`t apply a map to the preview colour just to make that clear.
RHaseltine posted Mon, 08 December 2003 at 5:39 AM
M2HeadTr.jpg is the Michael 2 lash transparency, in DAZCharactersMilMan in the Poser Textures folder: you load that as the transparency map, bottom right of the materials dialogure in Poser 4. However, if you look in the Pose library you should find a folder of MAT files which will do the colorisation and texture application for you - I can't remember the folder name, since I combine them to avoid running out of slots (Poser 4 is limited to 255 folders per library).
xantor posted Mon, 08 December 2003 at 6:52 PM
don`t you need propack to use MAT files?
RHaseltine posted Tue, 09 December 2003 at 6:18 AM
No - MAT files work with Poser 4 on, not sure about 3. Some MAT files don't work correctly with Poser 5.
DrOsborn posted Tue, 09 December 2003 at 8:47 AM
Rhaseltine, thanks for the advice. But if I let the MAT files do all the work for me, I wouldn't learn anything. :)
