Shiollie opened this issue on Dec 08, 2003 ยท 13 posts
Shiollie posted Mon, 08 December 2003 at 9:18 AM
I am trying to create an alpha plane using a blue and glod macaw parrot, but it seems that when the color pic and the black and white pic merge, the result is a very looking dull parrot, it is almost transparent. It is probably something simple that I am not catching.. any help?? Thank you Shiollie
gebe posted Mon, 08 December 2003 at 9:27 AM
Show what you get please so we can help. And make sure you use PURE white and black for the alpha.
Shiollie posted Mon, 08 December 2003 at 9:46 AM
gebe posted Mon, 08 December 2003 at 9:52 AM
This might be that your main image has not on a perfectly white background. It is also always important to use a highter resolution for the alpha (the black and white image) to create clean borders. I have never seen such effects, but I cannot imagine another reason. Somebody else?
sittingblue posted Mon, 08 December 2003 at 10:24 AM
As Guitta has pointed out, the alpha picture is not pure black and white, but uses shades of grey. Go into your photo editor and change the alpha picture making the grey parrot - black.
Charles
Charles
gebe posted Mon, 08 December 2003 at 10:31 AM
Attached Link: http://www.guitta.net/beginners/bitmap.html
You may have a look at this tutorial.gebe posted Mon, 08 December 2003 at 10:33 AM
BTW this is an old tutorial for Vue 2 or 3, I don't remember, but the "problem" is the same.
timefighter posted Mon, 08 December 2003 at 11:10 AM
It is very important that the second alpha is totaly black. If it is not, you get the results that you have. The black background allows the ture color to be placed on the alpha plane. As Guitta pointed out, it will also give you sharp clean borders and edges. James
Shiollie posted Mon, 08 December 2003 at 11:36 AM
Thank you everyone!! I tried to post a reply but when I hit the "post reply" button it keeps throwing me over to the master forum list, and my post goes floating off into cyberspace (I thought only msn did that :-/ ??) Everyone was right, I was just not seeing the true black and white untill I saw Guitta's tutorial and Sittingblue mentioned that my image had grey in it also. I finally got the results that I wanted! Thank you so much to everyone!! Good thing my motto is "To Live Is To Learn". Shiollie
rds posted Mon, 08 December 2003 at 3:28 PM
Attached Link: http://www.shoop3d.com/tut/tut.html
You can do this in Photo shop as well and I find it much easier to accomplish there is an AVI movie Tutorial at my site if you wish to down load it. That may be helpful. Regards, `shoop http://www.shoop3d.com/tut/tut.htmlShiollie posted Tue, 09 December 2003 at 8:30 AM
I just get that "Object not found" error message. Thanks tho. Shiollie
rds posted Tue, 09 December 2003 at 12:52 PM
Sorry about that due to heavy downloads my free area is close till Jan. 1 sorry about that myself. Reagards, `shoop
tradivoro posted Tue, 09 December 2003 at 10:48 PM
Shiollie, send me the picture, I'll make you an alpha image to use with real image...
