bazze opened this issue on Dec 09, 2003 ยท 10 posts
bazze posted Tue, 09 December 2003 at 3:07 AM
www.colacola.se
tjohn posted Tue, 09 December 2003 at 5:38 AM
bazze: I'm not clear on what your question is. 1. Do you want to know if your file should be that large? (Probably, if there are that many polygons involved.) 2. Do you want to know how to make the file smaller? (You could recreate your "rounded cube" object in Wings and try not to smooth it so much so you have fewer polys, then do some more smoothing in Bryce. Also, are there many cubes which aren't showing in your field of view? You might be able to delete some of them without affecting the pic as long as they aren't casting a shadow into the pic.) Or: 3. I'm entirely missing the point (not unusual for me) Hope this helps. John
bazze posted Tue, 09 December 2003 at 5:46 AM
Hi John, 1 & 2 answers my question. Thanks. That was also what I suspected.
www.colacola.se
Gog posted Tue, 09 December 2003 at 7:27 AM
Wow, 300 radials is a lot, did you play with sme of the advanced render options (such as smooth shadows and/or transitions) before you opted for more lights? Can you poly cull in wings i.e on the flat surfaces weld polys together so that the flat is a single larger poly?
bazze posted Tue, 09 December 2003 at 7:29 AM
No I'm using Bryce4 so there are no such options. Weld polys together on flat surfaces -good idea.. didn't think of that.
www.colacola.se
tjohn posted Tue, 09 December 2003 at 9:44 AM
Thanks, Gog, I'm still learning Wings and haven't gotten all the options down yet. :^)
Gog posted Tue, 09 December 2003 at 10:24 AM
Must admit I don't use wings, but most packages have a weld polys option of some form or other.
alvinylaya posted Tue, 09 December 2003 at 1:49 PM
I think you should talk to Ornlu, the master of simulated HDRI without the need of radials. You can also search for past topics in this forum regarding "HDRI" or "radiosity". The most recent ones: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=1554658 http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=1553996 and another: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=1553513&Reply=1553609#6
ysvry posted Tue, 09 December 2003 at 1:55 PM
this looks mighhty smooth can you do a little anim of it with the balls bouncing upndown on those smooth keys?
shadowdragonlord posted Tue, 09 December 2003 at 7:41 PM
Aye, but this is about as far as you can take it with Bryce 4, bazze! Great work, I might add. Very, very clean shadows...
