Butch opened this issue on Aug 20, 2000 ยท 2 posts
Butch posted Sun, 20 August 2000 at 10:02 PM
Just got Bryce (see earlier post), is there a difference between the version that I have, which is by Corel and the older version. The reason I ask is that so far no where in the manual does it mention Poser, yet my Poser manual does mention bryce several times.... In other words, can I load Poser figures and such into bryce? thanks butch
Hawkfyr posted Mon, 21 August 2000 at 12:05 AM
Yes you can butch, You may find references to Poser in the "working with other applications" section of the manual. Just Export your Poser figure as .obj or .3ds format from Poser. The import it in Bryce from the File.Import object command. good luck Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
