Subject: Wet Skin for V3
scarab1 opened this issue on Dec 11, 2003 ยท 11 posts
scarab1 posted Thu, 11 December 2003 at 1:35 PM
Attached Link: http://www.visual-redemption.com/redemption
I need to create a shower scene for the comic I'm working on. But I have no idea where or how to beging to create or use a texture map in Poser 5 that will make V3 look like she has wet skin with water droplets a rivlets on it... I was thinking maybe I could do it in post in PS but a good texture map to start with I'm thinking would be better... ...Any ideas?
stallion posted Thu, 11 December 2003 at 2:50 PM
Attached Link: http://www.runtimedna.com
RuntimeDNA have the Beach Babies textures which have that shinny wet look you ma want to check them out
You might as well PAY attention, because you can't afford FREE speech
panko posted Thu, 11 December 2003 at 2:54 PM
Maybe the BeachBaby V3 texture by Syyd Raven (from RDNA) would help you to start with and then do some postwork in Photoshop --that's what I'm doing in similar situations anyway.
"That's another fine mess you got me in to!" -- Oliver Hardy
panko posted Thu, 11 December 2003 at 2:57 PM
Ooops --cross-posting!... :)
stallion posted Thu, 11 December 2003 at 3:53 PM
Great minds think alike ;-)
estherau posted Thu, 11 December 2003 at 4:40 PM
I have that texture and it's great. Also if you make the highlight colour a light colour the skin will render as shiny which looks very good, and wet too. Also try tears in the search here and add those on to if you like. Love esther
MY ONLINE COMIC IS NOW LIVE
Ben_Dover posted Thu, 11 December 2003 at 5:39 PM
I thought I saw a tutorial here in the tutorials section not too long ago on making the "wet look". It was using post work though.
panko posted Thu, 11 December 2003 at 6:15 PM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=233
Correct Ben. And here is the link: http://www.renderosity.com/tut.ez?Form.ViewPages=233
Zarabanda posted Thu, 11 December 2003 at 7:16 PM
runtime dna has a set of skin tone mat poses by traveller that do this very well, generally "wet" characters can be easily created using skin highlights set to a light color in the poser materials setting, and then the plastic wrap filter in photoshop.
scarab1 posted Fri, 12 December 2003 at 11:06 AM
Thanks for all of the great ideas... here is what I have managed to do so far. As you can see I'm having some issues trying to get the neck area to match up correctly... any thoughts?
Allso her tattoo of the dangerous teddy looks a little blury, but in photoshop it looked fine, any thoughts on how I fix this?
The texture I'm using is "Chanee" by RNKarenEr
I just worked some new layers into it like water droplets (Are they any good)? and I tried to add some soapy bubbles... I'm not sure they turned out so well in the rendering, but they looked great on the skin map in Photoshop... I allso tried to apply Daniella's face make up from a V2 face file... not so sure how well I was able to pull that off either...
Any ideas?
Thoughts?
Curses? ;)
Michael
scarab1 posted Fri, 12 December 2003 at 3:11 PM
I was able to eventually figure out the neck texture matchup problem.... eventually...
Turns out there was a portion of the neck closest to the face that was still using the old texture... go figure... after telling it to apply the correct new texure I had made... well, tweaked ;) it finally worked...
... just a heads up incase someone else is having the same issue... took me the better part of the day to figure that one out... I kept opening the head & body map in photoshop scratching my head and pulling out my hair trying to figure out why they were not matching up... Oh well, live and learn.
I could still use some help on the other isues of why my tattoo looks a little out of focus when rendering. and if you figure my "soapy" areas look ok or if they could use some more work... I'll probably do a lot of that in post because I can then make the soap bubbles look like they are dripping off areas like her hips and stuff...
Thought?
Ideas?
Curses?
Praises?
Yeah, yeah... I don't want much do I.... c'pt maybe a six demon bag... full of wind, fire, and all that good stuff...
...course truth be told I feel like that after a good bowl of chillie ;)
Ramble, ramble, blah , blah...
... I'll just shut up now... ;)
