Subject: Texture Mapping Nightmare, Part 2, the problem with genetalia
RKane_1 opened this issue on Aug 21, 2000 ยท 10 posts
RKane_1 posted Mon, 21 August 2000 at 3:10 AM
Okay, Cage and Mason. I thank you for your help. I also found out that what I had to do was keep the .rsr for the modified .obj file so the computer would THINK it had the custom geometry even though the CR2 was pointed elsewhere. In essence, I am lying to Poser 4. The geometry is custom but the CR2 won't texture right if I let it know that so I let it build the .rsr with the custom geometry and then fixed the .CR2 file so that it would texture right. Okay, that said...problem #2 I modelled my figure on the P4 Male Nude with genetalia, but when I render with genetalia turned off, this happens. Um... Help. How do I make it so the groin is rendered smoothly?
