Forum: Vue
Subject: I won't get bigger.....:O(
Philywebrider opened this issue on Dec 12, 2003 ยท 8 posts
Philywebrider posted Fri, 12 December 2003 at 12:28 PM
I purchased a Elven Bridge from Daz, opened it in Propack, saved it as a PZ3. I then imported it into Vue. Everything seemed fine until I tried to enlarge it(by dragging the corners). It won't enlarge. What am I doing wrong. I have a PC with XP.
seeklight posted Fri, 12 December 2003 at 1:15 PM
lo you more than likely have to change the pivot point in the modle itself make the pivot point in the center of the modle i had this trouble and whne i did this it worked ok regards seeklight
Philywebrider posted Fri, 12 December 2003 at 1:44 PM
Errr...How do I change the Pivot point?
gebe posted Fri, 12 December 2003 at 2:10 PM
This way you can change the pivot point (here for a cube)
rds posted Mon, 15 December 2003 at 9:53 PM
Philywebrider? Did that work for you? I am just curious. Thanks.
Philywebrider posted Tue, 16 December 2003 at 1:14 AM
It worked. I found the pivotthing gebe showed and I sort of clicked here and there. The pivot moved I guess, because I was able to change the bridge size, but I don't really know how I did it. Thanks gebe, and everyone for giving me direction, hadn't the remotest idea where or what to do.
sacada posted Tue, 16 December 2003 at 6:55 PM
This is neat. I suppose this also helps with having to rotate objects that won't rotate. Solves lots of problems.
Tintifax posted Wed, 17 December 2003 at 7:49 AM
Can someone explain why this stuff behaves different? Did some props myself in C4D 6 CE and imported them as OBJ to Poser4. Saved them as props and hacked the files to get external geometry. Used them in a scene in Poser4 or 5 and saved the *.pz3. Then imported it to Vue 4.2 and never had a problem to resize or rotate it.
