Forum: Bryce
Subject: Tjohn's E.Z. Wood-Grain Mini-Tut (Bryce 5)
tjohn opened this issue on Dec 14, 2003 ยท 3 posts
tjohn posted Sun, 14 December 2003 at 4:09 AM
I have received kind comments about my wood-grain materials, so I thought some of you might like to see a tut. I'm a slow typist so please be patient. :^)
tjohn posted Sun, 14 December 2003 at 4:16 AM
1. Select the object you want to texture and give it the default material "Pine Wood" from the "Simple and Fast" folder. 2. Go into the DTE and turn off component 3 (unless you want holes). 3. Change the colors of the other 2 components to something closer to colors in the real world. Try different ways of combining component 1 and 2. I like "Multiply" because it gives such rich, deep tones. 4. Play with the sizing and orientation of your texture to fit the size and shape of your object. I also like to add a second texture for a bump map. I've made this paricular material reflective and shiny. Reflectivity helps this type of material work well with fake HDRI (see my pic "Atlas (Carry That Weight) for an example. I hope this is helpful. :^) John
mloates posted Sun, 14 December 2003 at 8:26 PM
Great tut--a really easy way to get some very good results. Thanks a bunch!
