Melansian_Mentat opened this issue on Dec 17, 2003 ยท 13 posts
Melansian_Mentat posted Wed, 17 December 2003 at 10:22 PM
Well, its another question for you guys. I'm trying to import files from www.3dlapidary.com into bryce. Every single time, it gets to the loading box, then freezes. Completely. Ctrl-alt-delete brings up the "bryce has encountered a problem and has to close" thing. I don't understand WHY I am having TROUBLE!!!
draculaz posted Wed, 17 December 2003 at 10:27 PM
the model is probably giving bryce the willies... if it's 3ds or lwv, try downloading wings3d (.com), importing it there, and exporting it again. should fix it. (i think) drac
danamo posted Thu, 18 December 2003 at 1:43 AM
3dlapidary has it's models all in the .dxf format.
danamo posted Thu, 18 December 2003 at 1:55 AM
I have found in my experience with Bryce that other model formats load much faster than .dxf. I have had big .dxf files take ten minutes or more to load. Sometimes they take so much time that it does seem like the program is frozen, but they load...most of the time. Lots of free progs out there to convert a .dxf to a more easily digested file like a .3ds or .obj file. Check out the Modeling Forum too. Maybe some of the other folks in the Forum can recommend some.
dan whiteside posted Thu, 18 December 2003 at 11:39 AM
I have a bunch of the free ones and I just tried a couple and they work for me. You've got the 5.0.1 update? It fixed some DXF problems. If not try another D/L and see if that file was corrupted. HTH; Dan
electroglyph posted Thu, 18 December 2003 at 12:53 PM
Attached Link: http://www.corel.com/servlet/Satellite?pagename=Corel/Products/Downloads&did=&id=1042551234521
You did unzip the files? Just asking. a few posts down in X-mas Tree help I posted links to the Bryce 5 update page and a thing called grouper to fix poser files. Grouper won't help but the Bryce update does something to help Bryce deal with extra line feeds or something in DXF files. If you haven't run the update, do. This link takes you to the Corel update page.Melansian_Mentat posted Thu, 18 December 2003 at 1:06 PM
Yes, they're unzipped. Yes, I have the update. No, it still don't work. I got a tip from the modeling forum that Rhino can import dxfs and export them as objs. It also has the explode option, so I think that will be the best solution.
electroglyph posted Thu, 18 December 2003 at 4:43 PM
I'm running a windows NT4 system with a pentium processor. I've got Bryce 5 with the update. I downloaded a bunch of these about a year ago they all import. If you downloaded corrupt files you should get a checksum error when you try to unzip. I tried downloading the button cut from the rounds and unzipped it fresh to my desktop. It imports fine. I'd hate to think you would have to convert these because they really should work as is. I don't have any other answers other than cycle the power, run defrag, and some kind or reg checker and see if the system is corrupt.
Melansian_Mentat posted Fri, 19 December 2003 at 12:59 AM
I can't understand yer lingo, Ringo! Don't ill-treat me pet dingo! Converting them won't mess up the actual objects, so as long as I get the same end results, I'm not sure it matters.
Rosemaryr posted Fri, 19 December 2003 at 3:46 AM
Tell me which models you're having problems with, please. I'll get them to you direct, if need be, in almost any other format you like. I would like to fix any problems that might arise from those downloads.
Rosemary Regan
3D Lapidary
Melansian_Mentat posted Fri, 19 December 2003 at 7:34 AM
I can't manage to load ANY of them. Bryce just freezes. I'm sure a good file convert will solve it, though. Don't fret about it.
Melansian_Mentat posted Fri, 19 December 2003 at 7:38 AM
Yeah. It worked. I just fed it through poser, and it worked. No worries!
electroglyph posted Fri, 19 December 2003 at 8:41 AM
Oz... That's the problem! Because you're in the southern hemisphere, you'll have to turn your keyboard upside down and type up;) Seriously, If you're happy that's great. I just wish I could tell you a way to make it work direct. I can't remember what I did to fix mine other than running the patch.
