Subject: Poser4 question
DarkMatter_ opened this issue on Dec 21, 2003 ยท 6 posts
DarkMatter_ posted Sun, 21 December 2003 at 5:13 PM
Why the hell is poser 4 turning my figures invisable when I use depthcue? I tried turning off all trans levels and that did even work.
mateo_sancarlos posted Sun, 21 December 2003 at 7:37 PM
Maybe they are too far back (-z-direction) from the object closest to the camera.
Nance posted Sun, 21 December 2003 at 10:08 PM
Depth Cueing is a transparency mask applied to objects in a progressivly greater amount based on the object's distance from the camera relative to the distance from the camera to the farthest polygon in the camera's field of view. You can cheat it somewhat by placing an invisible dummy prop much farther down the camera's viewing axis, thereby reducing the percentage of DQ that will be applied to the forground objects.
wyrwulf posted Sun, 21 December 2003 at 11:56 PM
As Nance said, put a prop into the scene, a primitive sphere or cube will do, and experiment with Ztrans of the prop to get the effect you want.
DarkMatter_ posted Mon, 22 December 2003 at 11:43 PM
That why, Thanks
Nance posted Tue, 23 December 2003 at 1:00 AM
Sheesh! Even I can't follow that sentence now. You'd think someone would invent a punctuation symbol to hang off the end of a word to indicate the beginning and end of a subordinate clause a phrase or separate items in a list.
