Forum: Photoshop
Subject: 3D glasses
josiahpugh opened this issue on Aug 25, 2000 ยท 11 posts
josiahpugh posted Fri, 25 August 2000 at 8:29 PM
I just got some 3D glasses today. A while back a saw a tutorial somewhere that told you how to make your art appear 3D through these glasses. Ya know, the red and blue ones. I think it said something about seperation the red and blue channels. If anybody knows where this tutorial is or know how to do this please help me!!! Thanks.
harold_u posted Sat, 26 August 2000 at 12:42 AM
All you have to do is when you have your picture go to the channels pallete, click on the red channel, and shift it a couple of pixels to the right side(you could use the arrow keys to keep it horizantal), When you go back to viewing it noraml, you'll see the effect, you can try shifting it more/less, what ever gives you the better result.
josiahpugh posted Sat, 26 August 2000 at 10:49 AM
That doesn't work. First of all it turns grey, and It won't let me move it b/c the target doesn't include all of the channels or something.
harold_u posted Sat, 26 August 2000 at 11:48 PM
What format are your images in? Ok...do it like this..You have to make sure that your image is in RGB mode. Go to Image->Mode and make sure that the check mark is set on "RBG Color ", Next click on the Channels tab...You should see 4 Layers...Your "RGB" Composite on top and the thumbnail showing it in coloer...The 3 other layer underneath it are your "Red, Green, and Blue" Channels, and the thumbnails should be in grayscale. Next click on the "Red" Channel and you should see the image turn into grayscale, that's because each channel is only 8 bits(256 colors)....once you are in the "Red" Channel use the move tool to move it a couple of pixels to the right...after moving the "Red" Channel click on the "RBG" layer on top of it, and you should see your image back in color. You can use your glasses to view it, and if necessary shift it less or more...what ever give you a better 3D picture.
adam posted Mon, 28 August 2000 at 4:43 PM
Just go here: http://www.chemicalstudios.com/tutorial/tut5/index.html ...FastTraxx made the best and easiest tutorial for anaglyphic images. By using this tutorial, I made this: http://3d-paradise.com/anaglyphic/cozyroom.html . Tell me what you think. Adam
josiahpugh posted Mon, 28 August 2000 at 6:22 PM
Oh THANK YOU!!!! That's the tutorial that I remembered!!! I didn't bookmark it so I couldn't find it again!! THANK YOU AGAIN!
adam posted Mon, 28 August 2000 at 9:05 PM
Thank FastTraxx...he's the one who made it.
KenS posted Tue, 29 August 2000 at 1:51 AM
Your welcome :)
josiahpugh posted Tue, 29 August 2000 at 7:48 PM
hey how'd you get a pic in there??
adam posted Tue, 29 August 2000 at 8:33 PM
type in (img src=http://???.jpg) Make sure the "(" is a "<" instead. The http://???.jpg is the URL of the image. So what I did was (img src=http://thibs.menloschool.org/~fanmail3d/smallsmile.jpg) but the ('s were <'s. -Adam
josiahpugh posted Wed, 30 August 2000 at 6:47 AM
neat
