Forum: Carrara
Subject: 3ds tree exports (C 3.03)
JWB opened this issue on Jan 01, 2004 ยท 8 posts
JWB posted Thu, 01 January 2004 at 4:24 AM
I am having trouble exporting trees as 3ds from Carrara 3.03. The export finishes, but there seem to a whole bunch of useless black jpgs and the import process back into C. 2.1, 3.03 or Vue 4.51 Professional is bad. No leaves seem to come back at all. I did get the palm tree to work, but it has a much smaller polygon count, with fewer elements. I am using Win XP 512 megs Ram and a PIII 1 GHz JWB
mmoir posted Thu, 01 January 2004 at 4:38 PM
JWB, I have never tried exporting trees, but did you play with the "mesh settings" in the tree modeller dialouge window. Mike
whkguamusa posted Thu, 01 January 2004 at 4:49 PM
Two things to look at: 1. Make sure the "Full Detail Mesh" option is checked or the leaves will not export. 2. Try this with the "obj" format. If you are using 3ds format it has a limit as to how many faces it can contain in one object. A bunch of leaves can easily pass that limit and instead of getting an export error message from Carrara you get an messy 3ds file with parts missing. mdc
ShawnDriscoll posted Thu, 01 January 2004 at 8:34 PM
I have a question. When exporting OBJ files from Carrara 3.0.3, what should I look for so that my objects aren't all gray colored when imported into other programs?
JWB posted Fri, 02 January 2004 at 9:47 AM
Using .obj export did give me the leaves, although Vue sometimes chokes. I still don't know why I get several uselessblack jpegs along with the useable textures. For Shonner: Be sure to check "convert procedural textures to texture maps" on the export dialog (if you're using 3ds, obj or 3dmf file types)
ShawnDriscoll posted Sun, 04 January 2004 at 8:34 PM
I've tried that. But my imported object is still all gray. Should I be looking for texture maps as individual jpegs in a folder somewhere? Or is the object supposed to have its texture maps included in it's file? www.shonner.com
wscottart posted Mon, 05 January 2004 at 12:58 PM
When I export an object I export the object to a new folder. That way the maps and everything are in one place. I have no idea why your models import gray. But you can find the maps if you place everything together in one spot. The export should include the maps and the object, and most likely a materials file.
ShawnDriscoll posted Tue, 06 January 2004 at 1:50 PM
Tonight I'll see if Bryce 5 can make heads or tails out of my Carrara 3 exports.
