Forum: Photography
Subject: Thumbs
Javafoto opened this issue on Jan 03, 2004 ยท 6 posts
Javafoto posted Sat, 03 January 2004 at 6:09 PM
Ok, I seem to be mentaly challenged. I am using Photoshop CS., but when i post images I cannot get a thumbnail to post with it. Anyone tell me the correct procedure? Thanks, Michael
3DGuy posted Sat, 03 January 2004 at 6:41 PM
umm First save your normal image, then resize your image to max 150x150 and then choose save for web to create your thumbnail (then you have 2 files, 1 original and one thumbnail)..
What is a friend? A single soul dwelling in two bodies. - Aristotle
-= Glass Eye Photography =- -= My Rendo Gallery =-
Michelle A. posted Sat, 03 January 2004 at 7:57 PM
If you are having trouble getting a thumb to upload at the same time as the full size image, it may be the way you are saving your thumbs in PS. As 3DGuy suggested use the "Save For Web" option. There is a problem with thumbs made in PS, using the regular "Save As" option and particular settings that may be used during that process, screw up something during the upload process. Let us know if that helps.
I am, therefore I create.......
--- michelleamarante.com
Javafoto posted Sun, 04 January 2004 at 8:18 AM
Thanks foor the info!
Thanks for the info!
Misha883 posted Tue, 06 January 2004 at 9:11 AM
(I'd like to keep my thumbs in a separate folder from my images, using the same name), however I've found that this does not work for 'osity. Does not like the image and the thumb to have the same name. (So, rather than what I'd like to do), I name the thumb something different, like "dytjdxt_t.jpg"
