Subject: Poser and Max Import Export problem!?
vladimirh opened this issue on Aug 29, 2000 ยท 3 posts
vladimirh posted Tue, 29 August 2000 at 9:18 PM
Hi everybody. I have problem with import to poser.When importing obj to max everything works fine but when I export and import to Poser all I have is box(is not fast tracking selection in poser)and I didn't touch obj in max just imported and exported and tryed and tryed. Does somebody have answer to this problem? Thank you Vlad
Viomar posted Wed, 30 August 2000 at 3:47 AM
You must use Harware's OBJ exp/Import Plugin for MAX! IT's the only one i know that's Consistant with Poser! I can't remember off Hand, Where to get it! Just do a search for "Max plugins" on the Net. Oh! And you must have the Latest Patch for Poser too! Marc
LoboUK posted Wed, 30 August 2000 at 4:15 AM
The HABWare OBJ plugins are essential when you're using MAX in conjunction with Poser. The plugins can be found in the free stuff section here - either do a search for habware, or check in the utilities section Paul
