Subject: My new clothing fits great in P5 and PPP but not in P4, Why?????
insomniaworks opened this issue on Jan 08, 2004 ยท 18 posts
insomniaworks posted Thu, 08 January 2004 at 5:59 PM
My new dress creation fits great in P5 and PPP but not in P4. I have no idea why I would act any differently in P4. Anyone have a clue? Thank you marty
PheonixRising posted Thu, 08 January 2004 at 7:26 PM
If you made it in P5 then there may be a backwards compatability issue. P5 is just ProPack with Plugins so they will work together. P5 is supposed to be backwards compatible but you might have run into a bug. I am just guessing that you used the set up room. If you can add more details it would help. Need more info from you to answer your question. 1)What doesn't work 2) Show pic prefferably both in P4 and P5 3)Circle desired effect. Circle problem area. Regards, Anton "Sometimes the most viloent of assasinations are commited with words" - Martha Jones
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
shadownet posted Thu, 08 January 2004 at 7:29 PM
Yes, more details are needed.
steveshanks posted Fri, 09 January 2004 at 3:47 AM
Did you change the obj and forget to delete the RSR file...Steve
insomniaworks posted Fri, 09 January 2004 at 10:45 AM
>Okay, it was created using PPP. I always work with PPP. >I always test it in another version of PPP before submision. >I also always test in P4 before submitting to the MP. My finished products are always P4 compatible with no version number error messages). I tested this dress in p5 after I saw there was a problem in P4 to see what would happen. Like I said before, the clothing fits exactly like it was designed in both ppp and P5. When I tested it in P4, the clothing product just didnt fit at all right. There were plenty of pokethrus all over the body and the dress formed new pokethrus alltogether when the dressed was figure was posed. I never saw this happen before and my jaw was left hanging. Yes, I have been doing lots of last minute tweeking to the obj and don't remember paying any special attention to the rsr. I thought that the rsr was just a thumbnail file - I never dreamed it had anything to do with the way P4 handled the geometry. What the heck does the rsr file have to do with the obj anyway? Until I get a reply, I am going to erase the rsr and try it again and see if it starts working right. What the heck! If I posted pictures for you with circles, it wouldn't do any good, I would just have a bunch of pokethrus circled in one picture and none in the other. I thought I would post a picture to this forum thread anyway, so here is what the dress looks like.
PheonixRising posted Fri, 09 January 2004 at 10:54 AM
Poser 4 has a special rsr in the geometries folder for reference on shape. My only guess is that the figure you have in your P4 runtime is not the same as the figure on your other runtimes. Other than that there is no reason why they wouldn't conform the same....EXCEPT....... If you used the PPP setup room to make the clothing that is likely the problem. The setup room is not stable. The safest and most reliable what to make clothes is still to make a phi files manually in a text editor. So if you are using the setup room that is what is causeing it and as far as I know there is no fix.
PheonixRising posted Fri, 09 January 2004 at 10:56 AM
Actually there is one last thing you can try. For clothes to conform properly they CANNOT be momorized in ANY pose other than absolute zero. 1)Zero CLothing 2) Zero HIP and Body 3)Memorize clothing figure and resave. If that doesnt work I don't know what to tell ya.
insomniaworks posted Fri, 09 January 2004 at 10:57 AM
I deleted the rsr file and let p4 make its own shrugging man thumb. I loaded the dress again in p4 and conformed the dress to the figure. There was a slight pokethru in one arm that should not have been there. I then posed her in this pose and got all these pokethrus. This doesn't happen in PPP. I would be willing to share the whole dress package if someone would like to look at it. Thank you Marty
PheonixRising posted Fri, 09 January 2004 at 11:09 AM
Check the figure for an active morph dial.
shadownet posted Fri, 09 January 2004 at 11:13 AM
Sounds like you deleted the wrong rsr file and got the rsr for the thumbnail. The rsr in P4 you want is in the geometry folder where the object for the dress is stored - or wherever you have the object target call path listed in the cr2, generally it is something like runtime:geometries:insomniaworks:dress.obj In this folderP4 will add an rsr dress.rsr that is what you want to delete.
insomniaworks posted Fri, 09 January 2004 at 11:18 AM
First of all, I didn't know there were suposed to be rsr files in the geometry folder. Where does an rsr come from, how is it created. Second) I do not use Set up room during the building process. Outside of of using magnets to tweek shape and saving the finished product cr2 with ppp. Thats all ppp has to do with the process of building. I always do some hand editing on the cr2 after it is saved to change version number and materials, and a few other things. I always use another cr2, a clothing one or an original one to begin with. In the case of this dress, I needed to use the original AnimeDoll.cr2 because so many of the body groups were represented in this peice of clothing. Outside of modeling software, I also use UVMapPro, which I highly recomend buying, for laying out UVmap, setting up the materials, and grouping the geometry. I also use CR2Editor by John Stallings for some editing and also do some editing by hand. I will also try to resave the goemetry in P4 as PheonixRising sugested, I was thinking of that anyway if it came to that to see what would happen. Although, I am not sure if it will work because when it loads, it is of course at absolue zero alreay and Dress overlays the AnimeDoll perfectly. It is not until I ask the dress to conform that the first poke thrus show up in one of the arms. Then the poke thrus multiply with poses. Then that brings me back to the rsr files in the geometry file which are absent. Will this create them? Thank you marty
PheonixRising posted Fri, 09 January 2004 at 11:21 AM
The rsr in the P4 geom folder is created by P4. I don't think that is your problem. Select the dress and click "Restore figure". If the dress changes shape or pose in anyway then that is your problem. See steps above.
insomniaworks posted Fri, 09 January 2004 at 11:30 AM
Where is "Restore Figure"? I never saw that anywhere in P4 or PPP. The first image below is both AnimeDoll and the dress loaded and still at absolute zero. The second picture is after the dress is conformed to AnimeDoll. You see the first pokethrus in the arm circled in red.
shadownet posted Fri, 09 January 2004 at 11:37 AM
On the menubar Edit>Restore>Figure or Shift+Ctrl+F hotkey for Windows OS. If it is loading right before conforming, try using the memorize figure command first, than conform the dress to the figure and see what happens. Edit>Memorize>Figure or Alt+Ctrl+F (for windows OS)
insomniaworks posted Fri, 09 January 2004 at 11:47 AM
Okay Shadownet, I Restored the figure and no shape or pose changes occured. I then memorized figure as you descibed and conformed, same poke thrus were there in the arm. No changes at all Did I say already that I can upload this to my file locker and you can download it and look at it your self? thank you marty
shadownet posted Fri, 09 January 2004 at 11:50 AM
I would be glad to look at it, but I do not have animedoll. Not up on all these anine figures, so I do not even know where to get it. Is this a free figure or a store item. I found Mayadoll at studioMaya.
insomniaworks posted Fri, 09 January 2004 at 12:03 PM
Yes, this works with Free MayaDoll also, actually it will look better on MayaDoll than AnimeDoll. Look for a Full Body Morph in the MiniDress called "MayaDollFit" that makes the minor changes to fit MayaDoll. I will IM you the location of the package. Thank you Shadownet marty
shadownet posted Fri, 09 January 2004 at 12:11 PM
Okay, sounds good. I will go grab the MayaDoll and then take a look at your package.
