Butch opened this issue on Jan 09, 2004 ยท 17 posts
Butch posted Fri, 09 January 2004 at 8:49 PM
Anyone know where I can find an old fashion hat pin? Thanks
hauksdottir posted Fri, 09 January 2004 at 11:08 PM
Can you make one? A dance cane or cylinder prop can be scaled to the right proportions. Add a fancy top thingy if you wish or just use a sphere... parent it to the pin, export as a single object, and then reimport at your desired size. Some of the Japanese hair pieces at the Edogoyomi site have what look like hairsticks, which could be scaled down to hat pin size as well. Carolly
randym77 posted Fri, 09 January 2004 at 11:12 PM
Butch posted Fri, 09 January 2004 at 11:45 PM
that's exactly what I need.I have tried in the past to make props but unfortunely I don't seem to have the knack for it. It like the old shop joke, no matter what I make it ends up being an ash try, just cut two grooves in it and you got an ash try...
randym77 posted Fri, 09 January 2004 at 11:53 PM
LOL! I'm sure someone will make one for you. If not, I can probably do it, beginner though I am. I'll check this thread tomorrow, and if the resident experts haven't stepped in, I'll take a stab at it. ;-)
Scarab posted Sat, 10 January 2004 at 1:06 AM
Do a net search for a free ware called "spatch"....it has a very very low learning curve but can produce simple props in dxf format which you can import into Poser. Cant be textured but still a usefull tool. Scarab
lesbentley posted Sat, 10 January 2004 at 8:16 AM
hecate posted Sat, 10 January 2004 at 9:50 AM
Scarab posted Sat, 10 January 2004 at 10:44 AM
Please do ....they are very nice... Scarab
Dizzie posted Sat, 10 January 2004 at 2:06 PM
DITTO...they're beautiful!
Dizzie posted Sat, 10 January 2004 at 2:33 PM
lesbentley, I tried your mini tut and I used the grouping tool to assign a new material to it called 'Ball'and did the same for the cyclinder but when I import it back in, there is no separate materials for the pin and ball...
hecate posted Sat, 10 January 2004 at 2:42 PM
randym77 posted Sat, 10 January 2004 at 2:57 PM
Wow, those are lovely! I knew someone would come through for Butch. :-D
hecate posted Sat, 10 January 2004 at 3:14 PM
Attached Link: http://www.fishyworld.net/model.php
Hatpins submitted to freestuff. For those who are impatient, here's a direct link to the site. 8-) Hope they're enjoyed.Dizzie posted Sat, 10 January 2004 at 5:19 PM
These are great! Thanks!
hauksdottir posted Sat, 10 January 2004 at 5:35 PM
Very pretty set of pins... thank you!
Scarab posted Sat, 10 January 2004 at 5:59 PM
Yay! 8) S.
